数据:
TPS53353 高效 20A 同步降压转换器,具有 Eco-mode 数据表 (Rev. B)
TPS53353是一款具有集成MOSFET的D-CAP™模式,20A同步降压转换器。它们被设计用于易于使用,低外部组件数量和空间有限的电源系统。
这个器件特有5.5mΩ/2.2mΩ集成MOSFET,精准1%0.6V基准和集成的升压开关。具有竞争力的特性包括:1.5V至15V的转换输入电压范围,极低外部元件数,针对超快速瞬态响应的D-CAP™模式控制,自动跳跃模式操作,内部软启动控制,可选择频率以及无需补偿。
转换输入电压范围为1.5V至15V,电源电压范围为4.5V至5.5V。
该器件采用5mm×6mm,22引脚QFN封装,额定工作温度范围为-40°C至85°C。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS53353 | TPS51362 | TPS53318 | TPS53319 | TPS53355 | TPS543B20 | TPS543C20 | TPS544C25 | TPS548B22 | TPS548D22 | TPS56121 | TPS56221 | TPS56520 | TPS566250 | TPS56628 | TPS56720 |
| 1.5 | 3 | 1.5 | 1.5 | 1.5 | 4 | 4 | 4.5 | 1.5 | 1.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 15 | 22 | 22 | 22 | 15 | 19 | 16 | 18 | 18 | 16 | 14 | 14 | 17 | 17 | 18 | 17 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.5 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.76 | 0.6 |
| 5.5 | 2 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 | 12 | 12 | 1.87 | 1.87 | 5.5 | 1.87 |
| 20 | 10 | 8 | 14 | 30 | 25 | 40 | 30 | 25 | 40 | 15 | 25 | 5 | 6 | 6 | 7 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 250 | 800 | 250 | 250 | 250 | 300 | 300 | 200 | 425 | 425 | 300 | 300 | 500 | 500 | 650 | 500 |
| 1000 | 800 | 1000 | 1000 | 1000 | 2000 | 2000 | 1000 | 1050 | 1050 | 1000 | 1000 | 500 | 500 | 650 | 500 |
| 0.32 | 0.1 | 0.32 | 0.32 | 0.32 | 3 | 4.3 | 7.7 | 2 | 2 | 2.5 | 2.5 | 0.92 | 0.9 | 0.95 | 0.92 |
| Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization N/A Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining |
| D-CAP | D-CAP2 | D-CAP | D-CAP | D-CAP | Current Mode | Current Mode | Voltage Mode | D-CAP3 | D-CAP3 | Voltage Mode | Voltage Mode | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 90 | 87 | 90 | 90 | 90 | 70 | 70 | 80 | 80 | 80 | 93 | 93 | 80 | 80 | 85 | 80 |
| -40 to 85 | -10 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| LSON-CLIP | VQFN-CLIP | LSON-CLIP | LSON-CLIP | LSON-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LSON-CLIP | LSON-CLIP | HTSSOP | SO PowerPAD | SO PowerPAD | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
