数据:
TPS6213x 采用 3x3 QFN 封装的 3V 至 17V/3A 降压转换器 数据表 (Rev. E)
TPS6213X系列是一款简单易用的同步降压DC-DC转换器,针对高功率密度的应用进行了优化。该器件的开关频率典型值高达2.5MHz,允许使用小型电感,利用DCS-Control™拓扑技术提供快速瞬态响应并实现高输出电压精度。
该器件的宽运行电压范围为3V至17V,非常适用于由锂离子或其他电池以及12V中间电源轨供电的系统。它在输出电压介于0.9V至6V之间时支持高达3A的持续输出电流(使用100%占空比模式)。输出电压启动斜坡由软启动引脚控制,从而允许作为独立电源或者在跟踪配置下的运行。通过配置使能和开漏电源正常引脚也有可能实现电源排序。
在节能模式下,该器件在输入电压V IN 作用下生成约17μA的静态电流。如果负载小,则自动且无缝进入省电模式,在全部负载范围内保持高效率。在关断模下,此器件被关闭且关断流耗少于2μA。
此器件分为可调和固定输出电压型号,采用3mm×3mm(RGT)16引脚超薄四方扁平无引线( VQFN)封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62130 | TPS62136 | TPS62140 | TPS62150 | TPS62180 |
| 3 | 3 | 3 | 3 | 4 |
| 17 | 17 | 17 | 17 | 15 |
| 0.9 | 0.8 | 0.9 | 0.9 | 0.9 |
| 6 | 12 | 6.3 | 6.3 | 6 |
| 3 | 4 | 2 | 1 | 6 |
| 1 | 1 | 1 | 1 | 1 |
| 1250 | 1000 | 1250 | 1250 | 1000 |
| 2500 | 1000 | 2500 | 2500 | 2000 |
| 0.017 | 0.018 | 0.017 | 0.017 | 0.03 |
| Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Tracking Voltage Margining | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN | VQFN-HR | VQFN | VQFN | DSBGA |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
