数据:
带有集成场效应晶体管 (FET) 的 4A/2A 双通道同步降压转换器 数据表 (Rev. A)
TPS54495是一款双路,自适应接通时间D-CAP2™模式同步降压转换器.TPS54495可帮助系统设计人员通过成本有效性,低组件数量,和低待机电流解决方案来完成各种终端设备的电源总线调节器集.TPS54495的主控制环路采用D-CAP2™模式控制,无需外部补偿组件即可提供极快的瞬环境应用接通时间控制支持更高负载状态下的脉宽调制(PWM)模式与轻负载下的Eco-mode™工作模式之间的无缝转换.Eco-mode™使TPS54495能够在较低TPS54495能够采用诸如高分子有机半导体固体电容器(POSCAP)或者高分子聚合物电容器(SP-CAP)等低等效串联电阻(ESR)和超低ESR陶瓷电容器。在输入电流为4.5V至18V之间时提供便捷和有效的运行。
TPS54495采用4.4mm x 5mm 16引脚TSSOP(PWP)封装和4mm x 4mm 16引脚VQFN(RSA)封,并针对-40°C至85℃的环境温度范围内的运行而设计。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54495 | TPS54294 | TPS542941 | TPS54295 | TPS542951 | TPS54394 | TPS54395 | TPS54494 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.8 | 4.5 | 4.5 |
| 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
| 0.75 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
| 4 | 2 | 2 | 2 | 2 | 3 | 3 | 4 |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| 700 | 700 | 700 | 700 | 700 | 700 | 700 | 700 |
| 1.2 | 1.3 | 1.3 | 1.3 | 1.3 | 1.2 | 1.2 | 1.2 |
| Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Phase Interleaving Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
