数据:
带有集成场效应晶体管 (FET) 的 2A/3A 双通道同步降压转换器, TPS542941 数据表 (Rev. A)
TPS542941是一款双路,自适应接通时间D-CAP2™模式同步降压转换器.TPS542941可帮助系统设计人员通过成本有效性,低组件数量,和低待机电流解决方案来完成多种终端设备的电源总线调节器集.TPS542941的主控制环路采用D-CAP2™模式控制,此模式控制无需外部补偿组件即可提供极快的瞬态响应。自适应接通时间控制支持较高负载状态下的脉宽调制(PWM)模式与轻负载下的Eco-mode™工作模式之间的无缝转换.Eco-mode™使用TPS542941能够在较轻负载条件下保持高效率.TPS542941能够采用诸如高分子有机半导体固体电容器(POSCAP)或者高分子聚合物电容器(SP-CAP)等低等效串联电阻(ESR)和超低陶瓷电容器。 TPS542941采用4.4mm x 5.0mm 16引脚TSSOP(PWP)封装和4mm x 4mm 16引用VQFN(RSA)封装,额定环境运行温度范围为-40°C至85℃。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS542941 | TPS54294 | TPS54295 | TPS542951 | TPS54394 | TPS54395 | TPS54494 | TPS54495 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.8 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
| 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.75 |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
| 2 | 2 | 2 | 2 | 3 | 3 | 4 | 4 |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| 700 | 700 | 700 | 700 | 700 | 700 | 700 | 700 |
| 1.3 | 1.3 | 1.3 | 1.3 | 1.2 | 1.2 | 1.2 | 1.2 |
| Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Phase Interleaving Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN | HTSSOP QFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
