数据:
TPS6206x-Q1 采用 2 × 2 SON 封装的 3MHz 2A 降压转换器 数据表
TPS62065-Q1和TPS62067-Q1器件是一款高效同步降压DC-DC转换器。该器件可提供高达2A的输出电流。 TPS62065-Q1和TPS62067-Q1工作在3MHz固定频率下,并且在轻负载电流条件下会进入节能模式,从而在整个负载电流范围内保持高效率。该节能模式针对低输出电压纹波进行了优化。对于低噪声应用,可通过将MODE引脚拉为高电平模强制TPS62065-Q1器件进入固定频率PWM模式.TPS62067-Q1提供了开漏电源正常输出。在关断模式下,电流消耗降至5μA,同时内部电路将使输出电容放电.TPS62065-Q1和TPS62067 -Q1器件经过了优化,可与微型1μH电感以及小型
10μF输出电容搭配工作,从而实现了最小解决方案尺寸以及高稳压性能。
TPS62065-Q1和TPS 62067-Q1器件采用小型2×2×0.75mm 8引脚WSON封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62065-Q1 | TLV620612-Q1 | TLV62065-Q1 | TPS62067-Q1 | TPS62090-Q1 | TPS62097-Q1 | TPS62290-Q1 |
| 2.9 | 2.9 | 2.9 | 2.9 | 2.5 | 2.5 | 2.3 |
| 6 | 5.5 | 5.5 | 6 | 6 | 6 | 6 |
| 0.8 | 1.2 | 0.8 | 0.8 | 0.8 | 0.8 | 0.6 |
| 6 | 1.2 | 5.5 | 6 | 6 | 6 | 6 |
| 2 | 1.6 | 2 | 2 | 3 | 2 | 1 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2600 | 2600 | 2600 | 2600 | 1400 | 1500 | 2250 |
| 3400 | 3400 | 3400 | 3400 | 2800 | 2500 | 2250 |
| 0.018 | 0.018 | 0.018 | 0.018 | 0.02 | 0.04 | 0.015 |
| Enable Light Load Efficiency Output Discharge Spread Spectrum Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Spread Spectrum Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Synchronous Rectification | Enable Light Load Efficiency Output Discharge Spread Spectrum Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Wettable Flanks Package | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 105 | -40 to 105 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 105 -40 to 85 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| WSON | WSON | WSON | WSON | VQFN | VQFN | WSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
