数据:
4.5V 至18V 输入,6.5A 同步降压转换器 数据表
TPS54625是一款自适应接通时间D-CAP2模式同步降压转换器.TPS54625可帮助系统设计人员用成本有效,低组件数量,低待机电流解决方案来完成不同终端设备的电源总线调节器集。
TPS54625的主控制环路使用D-CAP2模式控制,此控制方式提供一个无需外部补偿组件的极快速瞬态响应.TPS54625的专有电路还使该器件可采用诸如高分子有机半导体固体电容器(POSCAP)或高分子聚合物电容器(SP-CAP)等低等效串联电阻(ESR)输出电容器以及超低ESR陶瓷电容器。该器件的工作电压介于4.5V至18V的VIN输入之间。输出电压可在0.76V与5.5V之间进行编程。该器件还特有一个可调软启动时间和一个电源正常功能TPS54625采用14引脚散热薄型小外形尺寸(HTSSOP)封装,设计工作温度介于-40°C到85°C之间。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54625 | TPS54225 | TPS54226 | TPS54325 | TPS54326 | TPS54425 | TPS54426 | TPS54429 | TPS54429E | TPS54525 | TPS54526 | TPS54626 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 7 | 7 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
| 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 6.5 | 2 | 2 | 3 | 3 | 4 | 4 | 4.5 | 4.5 | 5.5 | 5.5 | 6.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 650 | 700 | 700 | 700 | 700 | 700 | 700 | 700 | 700 | 650 | 650 | 650 |
| 0.95 | 0.8 | 0.8 | 0.85 | 0.85 | 0.85 | 0.85 | 0.85 | 0.85 | 0.9 | 0.9 | 0.95 |
| Enable Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 95 | 90 | 90 | 90 | 90 | 90 | 90 | 98 | 98 | 95 | 95 | 95 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -20 to 85 | -20 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP VQFN | HTSSOP | HTSSOP VQFN | HTSSOP | HTSSOP QFN | HTSSOP | HTSSOP QFN | HTSSOP | HTSSOP QFN | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
