数据:
4.5V 至 18V 输入、5.5A 同步降压转换器 数据表 (Rev. A)
TPS54525是一款自适应接通时间D-CAP2模式同步降压转换器.TPS54525可帮助系统设计人员通过低成本,低组件数量的低待机电流解决方案来完成各种终端设备的电源总线调节器集.TPS54525的主控制环路使用D-CAP2模式控制,此控制方式提供一个无需外部补偿组件的极快速瞬态响应.TPS54525的专有电路还有助于该器件适应诸如POSCAP或SP-CAP等低等效串联电阻(ESR)输出电容器以及超低ESR陶瓷电容器。该器件的工作输入电压介于4.5V至18V VIN之间。输出电压可在0.76 V与5.5 V之间进行编程。该器件还特有一个可调软启动时间和一个电源正常功能.TPS54525采用14引脚散热薄型小外形尺寸(HTSSOP)封装,设计工作温度介于-40°C到85°C之间。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54525 | TPS54225 | TPS54226 | TPS54325 | TPS54326 | TPS54425 | TPS54426 | TPS54429 | TPS54429E | TPS54526 | TPS54625 | TPS54626 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 7 | 7 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
| 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 5.5 | 2 | 2 | 3 | 3 | 4 | 4 | 4.5 | 4.5 | 5.5 | 6.5 | 6.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 650 | 700 | 700 | 700 | 700 | 700 | 700 | 700 | 700 | 650 | 650 | 650 |
| 0.9 | 0.8 | 0.8 | 0.85 | 0.85 | 0.85 | 0.85 | 0.85 | 0.85 | 0.9 | 0.95 | 0.95 |
| Enable Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 95 | 90 | 90 | 90 | 90 | 90 | 90 | 98 | 98 | 95 | 95 | 95 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -20 to 85 | -20 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP VQFN | HTSSOP | HTSSOP VQFN | HTSSOP | HTSSOP QFN | HTSSOP | HTSSOP QFN | HTSSOP QFN | HTSSOP | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
