数据:
带有 DCS™ 控制的 3A 高效同步降压转换器, TPS6209x 数据表 (Rev. A)
TPS6209x器件是一款高效同步降压转换器,此转换器针对小外形尺寸,高效应用进行了优化并适合于电池供电类应用。为了最大限度地提升效率,此转换器运行在2.8 MHz /1.4 MHz的标称开关频率的脉宽调制(PWM)模式下并在轻负载时自动进入省电运行模式。当被用于分布式电源和负载点调制时,此器件允许到其它电源轨的电压跟踪并且耐受范围在10μF到高达150μF甚至更高的输出电容。通过使用DCS™控制技术,此器件可实现出色的负载静态性能以及精确的输出电压调制。
此输出电压启动斜波由软启动引脚控制,从而使器件可作为独立电源运行或运行在跟踪配置下。通过配置使能和开漏电源正常引脚也有可能实现电源排序。在省电模式下,此器件运行在典型值为20μA静态电流下。在全部负载电流范围内,自动进入省电式并且无缝保持高效。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62090 | TPS62136 | TPS62480 | TPS62823 | TPS62826 |
| 2.5 | 3 | 2.4 | 2.4 | 2.4 |
| 6 | 17 | 5.5 | 5.5 | 5.5 |
| 0.8 | 0.8 | 0.6 | 0.6 | 0.6 |
| 6 | 12 | 5.5 | 4 | 4 |
| 3 | 4 | 6 | 3 | 3 |
| 1 | 1 | 1 | 1 | 1 |
| 1400 | 1000 | 2000 | 2200 | 2200 |
| 2800 | 1000 | 2500 | 2200 | 2200 |
| 0.02 | 0.018 | 0.023 | 0.004 | 0.004 |
| Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN | VQFN-HR | VQFN-HR | VSON-HR | VSON-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
