数据:
TPS6208x 采用 2x2 QFN 封装且具有自动切断短路保护功能的 3A 降压转换器 数据表 (Rev. A)
TPS62085,TPS62086和TPS62087器件是高频同步降压转换器,经优化具有小解决方案尺寸和高效率两大优点。该器件具有2.5V至6.0V的输入电压范围,
支持常见的电池技术。此转件器在中输程宽调制(PWM)模式,并在轻负载时自动进入省电模式运行,从而在整个负载电流轨道内保持高效率。
为了满足系统电源轨的需求,内部补偿电路支持10μF到达150uF的宽范围外部输出电容值选项。凭借DCS-Control架构,该器件可实现出色的负载瞬态性能和输出稳压精度。这些器件采用2mm x 2mm QFN封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62085 | TLV62569 | TPS62088 | TPS62136 | TPS62480 | TPS62801 | TPS62802 | TPS62806 | TPS62823 | TPS62825 | TPS62826 |
| 2.5 | 2.5 | 2.4 | 3 | 2.4 | 1.8 | 1.8 | 1.8 | 2.4 | 2.4 | 2.4 |
| 6 | 5.5 | 5.5 | 17 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 0.8 | 0.6 | 0.6 | 0.8 | 0.6 | 0.8 | 1.8 | 0.4 | 0.6 | 0.6 | 0.6 |
| 6 | 5.5 | 4 | 12 | 5.5 | 1.55 | 3.3 | 0.775 | 4 | 4 | 4 |
| 3 | 2 | 3 | 4 | 6 | 1 | 1 | 0.6 | 3 | 2 | 3 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2400 | 1500 | 4000 | 1000 | 2000 | 4000 | 4000 | 1500 | 2200 | 2200 | 2200 |
| 2400 | 1500 | 4000 | 1000 | 2500 | 4000 | 4000 | 1500 | 2200 | 2200 | 2200 |
| 0.017 | 0.035 | 0.004 | 0.018 | 0.023 | 0.0023 | 0.0023 | 0.0023 | 0.004 | 0.004 | 0.004 |
| Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed |
| Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | DCS-Control | DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VSON-HR | SOT-23 SOT-23-THIN SOT-5X3 | DSBGA | VQFN-HR | VQFN-HR | DSBGA | DSBGA | DSBGA | VSON-HR | VSON-HR | VSON-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
