数据:
TPS6274x 针对低功耗应用的 360nA IQ 降压转换器 数据表 (Rev. B)
TPS6274x是业界第一款降压转换器,此转换器特有典型值为360nA的静态电流,并且搭配微型2.2μH电感和10μF输出TITS62740支持高达300mA的输出电流,TPS62742支持高达400mA的输出电流。电池,锂化学电池(例如锂亚硫酰氯(Li-SOC12),锂锰电池(Li-MnO2)和两节或三节碱性电池)供电运行。输入电压范围高达5.5V,也实现由1个USB端口和薄膜太阳能模块供电运行。用户可使用4个VSEL引脚在1.8V至3.3V范围内选择输出电压(步长100mV).TPS6274x搭配使用小型输出电容,特有低输出纹波电压和低噪声。一旦电池电压接近输出电压(接近100%占空比),此器件进入无纹波100%模式运行,以防止输出纹波电压的增加然后,此器件停止开关,并且输出被连接至输入电压。集成转换率受控负载开关特有典型值为0.6Ω的导通电阻,并且将选择的输出电压分配至临时使用的子系统.TPS6274采用小型12引脚2mm x 3mm 2 WSON封装,并且支持31mm 2 的总体解决方案尺寸。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62740 | TPS62125 | TPS62175 | TPS62230 | TPS62671 | TPS62742 | TPS62745 | TPS62746 | TPS62748 | TPS62821 |
| 2.2 | 3 | 4.7 | 2.05 | 2.3 | 3 | 3.3 | 2 | 2.15 | 2.4 |
| 5.5 | 17 | 28 | 6 | 4.8 | 5.5 | 10 | 5.5 | 5.5 | 5.5 |
| 1.8 | 1.2 | 1 | 2.5 | 1.8 | 1.8 | 1.8 | 1.2 | 1.2 | 0.6 |
| 3.3 | 10 | 6 | 2.5 | 1.8 | 3.3 | 3.3 | 3.3 | 1.8 | 4 |
| 0.3 | 0.3 | 0.5 | 0.5 | 0.5 | 0.4 | 0.3 | 0.3 | 0.3 | 1 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2000 | 1000 | 1000 | 2000 | 5400 | 2000 | 2500 | 1200 | 1200 | 2200 |
| 2000 | 1000 | 1000 | 3000 | 6600 | 2000 | 2500 | 1200 | 1200 | 2200 |
| 0.0003 | 0.013 | 0.0048 | 0.022 | 0.017 | 0.0003 | 0.0004 | 0.0003 | 0.00036 | 0.004 |
| Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Spread Spectrum Synchronous Rectification | Dynamic Voltage Scaling Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Synchronous Rectification | Load Disconnect | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Voltage Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| WSON | WSON | WSON | SON | DSBGA | WSON | WSON | DSBGA | DSBGA | VSON-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
