数据:
TPS54561 具有软启动和 Eco-mode™ 的 4.5V 至 60V 输入、5A、降压 DC-DC 转换器 数据表 (Rev. F)
TPS54561是一款60V,5A,降压稳压器,此稳压器具有一个集成的高侧MOSFET。按照ISO 7637标准,此器件能够耐受的抛负载脉冲高达65V。电流模式控制提供了简单的外部补偿和灵活的组件选择。一个低纹波脉冲跳跃模式将无负载时的电源电流减小至152μA。当使能引脚被拉至低电平时,关断电源电流被减少至2μA。
欠压闭锁在内部设定为4.3V,但可用一个使能引脚上的外部电阻分压器将之输出电压启动斜坡由软启动引脚控制,该引脚还可被配置用来控制定序/跟踪。一个开漏电源正常信号表示输出处于其标称电压的93%至106%之内。
宽可调开关频率范围可针对效率或者外部组件尺寸进行优化。逐周期电流限制,频率折返和热关断在过载条件下保护内部和外部组件。
TPS54561采用10引脚4mm x 4mm WSON封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54561 | TPS54060A | TPS54160A | TPS54361 | TPS54361-Q1 | TPS54560 | TPS54561-Q1 |
| 4.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 60 | 60 | 60 | 60 | 60 | 60 | 60 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 59 | 58 | 58 | 59 | 59 | 58.8 | 59 |
| 5 | 0.5 | 1.5 | 3.5 | 3.5 | 5 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.152 | 0.116 | 0.116 | 0.152 | 0.152 | 0.146 | 1.52 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Automotive | Catalog | Automotive |
| WSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | WSON | WSON | SO PowerPAD | WSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
