数据:
TPS544x20 4.5V 至 18V,20A 和 30A SWIFT 同步降压控制器(具有 PMBus 数据表 (Rev. B)
TPS544B20和TPS544C20器件是PMBus兼容型非隔离式直流/直流集成式FET转换器,支持高频运行并提供20A或30A电流输出,采用5mm×7mm封装,可实现高功率密度和快速瞬态性能,具有最小的PCB面积.PMBus接口用于转换器配置,并且监视关键参数,其中包括输出电压,电流和一个可选外部温度。集成NexFET功率级和经优化驱动器提供的高频,低损耗开关可实现极高密度电源解决方案以及减小的电感器和滤波电容器尺寸。根据系统要求,对故障情况的响应可被设定为重新启动或锁断。
所有商标ar e各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS544B20 | TPS544B25 | TPS544C20 | TPS544C25 |
| 4.5 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 18 |
| 0.6 | 0.5 | 0.6 | 0.5 |
| 5.5 | 5.5 | 5.5 | 5 |
| 20 | 20 | 30 | 30 |
| 1 | 1 | 1 | 1 |
| 250 | 200 | 250 | 200 |
| 1000 | 1000 | 1000 | 1000 |
| 8 | 9.5 | 8 | 7.7 |
| Adjustable Current Limit Dynamic Voltage Scaling Enable PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining |
| D-CAP D-CAP2 | Voltage Mode | D-CAP D-CAP2 | Voltage Mode |
| 80 | 80 | 80 | 80 |
| -40 to 85 | -40 to 125 | -40 to 85 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog |
| LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
