数据:
TPS54541 具有软启动和 Eco-mode™ 的 4.5V 至 42V 输入、5A、降压 DC-DC 转换器 数据表 (Rev. C)
TPS54541器件是一款42V 5A降压型稳压器,此稳压器具有一个集成型高侧MOSFET。按照ISO 7637标准,此器件能够耐受高达45V的抛负载脉冲。电流模式控制提供了简单的外部补偿和灵活的组件选择。一个低纹波脉冲跳跃模式将无负载输出电源电流减小至152μA。使能引脚下拉为低电平后,关断电源电流降至2μA。
欠压闭锁在内部设定为4.3V,但可用一个使能引脚上的外部电阻分压器将之提高。电压启动斜坡受控于软启动引脚,该引脚还可被配置用来控制电源排序和跟踪。一个开漏电源正常信号表示输出处于标称电压值的93%至106%之内。
宽可调开关频率范围可针对效率或者外部组件尺寸进行优化。逐周期电流限制,频率折返和热关断功能可在过载情况下保护内部和外部组件。
TPS54541器件采用10引脚4mm x 4mm WSON封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54541 | TPS54040A | TPS54140A | TPS54240 | TPS54340 | TPS54341 | TPS54540 |
| 4.5 | 3.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 |
| 42 | 42 | 42 | 42 | 42 | 42 | 42 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 41 | 39 | 39 | 39 | 41 | 41 | 41.1 |
| 5 | 0.5 | 1.5 | 2.5 | 3.5 | 3.5 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.152 | 0.116 | 0.116 | 0.138 | 0.146 | 0.152 | 0.146 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| WSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | SO PowerPAD | WSON | SO PowerPAD |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
