TPS53515是一款具有自适应接通时间D-CAP3模式控制的小尺寸,单通道降压转换器。此器件为空间有限的电源系统提供易于使用且低外部组件数量。
这个器件特有高性能集成MOSFET,精准0.5%0.6V基准和集成的升压开关。竞争优势包括极低外部组件数量,快速负载瞬态响应,自动跳跃模式运行,内部软启动控制,并且无需补偿。
转换输入电压范围介于1.5V至22V之间.VDD输入电压的范围介于4.5V至25V之之。间。输出电压范围为0.6V至5.5V.TPS53515采用28引脚QFN封装,额定温度范围介于-40°C至+ 85°C之间。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS53515 | TPS53513 | TPS53915 | TPS54020 | TPS548A20 | TPS549A20 |
| 1.5 | 1.5 | 1.5 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 17 | 20 | 20 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
| 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 |
| 12 | 8 | 12 | 10 | 15 | 15 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 250 | 250 | 250 | 200 | 250 | 250 |
| 1000 | 1000 | 1000 | 1200 | 1000 | 1000 |
| 1.35 | 1.35 | 1.35 | 0.6 | 1.35 | 1.35 |
| Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable Voltage Margining |
| D-CAP3 | D-CAP3 | D-CAP3 | Current Mode | D-CAP3 | D-CAP3 |
| 80 | 80 | 80 | 98 | 50 | 50 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 150 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN-CLIP | VQFN-CLIP | VQFN-CLIP | VQFN-HR | VQFN-CLIP | VQFN-CLIP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
