数据:
TPS40428 支持自适性电压调节 (AVS) 总线的双路输出、双相、堆栈式 PMBus 同步降压无驱动器控制器 数据表 (Rev. A)
TPS40428器件是一款PMBus同步降压无驱动器控制器。其出厂默认设置的工作模式为智能功率模式,在进行PMBus编程并重启电源之后即可在非智能功率模式下工作。该器件可配置为双路输出或双相操作。而且该器件最多可堆叠4个相位,支持高达120A的负载电流.2相,3相或4相交错式相移可减少输入和输出波纹,从而减小输入和输出电容。
它的宽输入电压范围可支持5V和12V中间电源总线。基准电压精度达0.5%,可满足现代专用集成电路(ASIC)对于精准电压的需求。
根据PMBus标准,TPS40428器件可对基准电压,故障限制,UVLO阈值,软启动时间以及接通和关断延迟进行编程。
此外,该器件还实现了精准的测量系统,用于监视各通道的输出电压,电流和温度。
要了解所有可用封装,请见数据表末尾的可订产品附录
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS40428 | TPS40422 | TPS40425 | TPS53647 | TPS53667 | TPS53681 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 20 | 20 | 20 | 17 | 17 | 17 |
| 0.6 | 0.6 | 0.6 | 0.5 | 0.5 | 0.25 |
| 5 | 5.6 | 5 | 2.5 | 2.5 | 2.8125 |
| 40 | 60 | 40 | 240 | 420 | 300 |
| 2 | 2 | 2 | 1 | 1 | 2 |
| 2 | 2 | 2 | 4 | 6 | 8 |
| 200 | 200 | 200 | 300 | 300 | 300 |
| 1500 | 1000 | 1500 | 1000 | 1000 | 1000 |
| 18 | 18 | 18 | 8 | 6.1 | 13 |
| Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Dynamic Voltage Scaling Enable Frequency Synchronization Multiple Outputs PMBus Phase Interleaving Remote Sense | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Multiple Outputs PMBus Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining |
| 46 | 90 | 46 | 50 | 50 | 50 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN | VQFN WQFN | VQFN | WQFN | WQFN | WQFN |
| Voltage Mode | Voltage Mode | Voltage Mode | D-CAP+ | D-CAP+ | D-CAP+ |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
