数据:
支持软启动和Eco-Mode™ 的4.5V 至42V 输入,3.5A 降压直流- 直流转42V 输入,3.5A 降压直流- 直流转 数据表
TPS54341器件是一款42V 3.5A降压型稳压器,此稳压器具有一个集成型高侧MOSFET。按照ISO 7637标准,此器件能够耐受高达45V的抛负载脉冲。电流模式控制提供了简单的外部补偿和灵活的组件选择。一个低纹波脉冲跳跃模式将无负载输出电源电流减小至152μA。当使能引脚被拉至低电平时,关断电源电流被减少至2μA。
欠压闭锁在内部设定为4.3V,但可用一个使能引脚上的外部电阻分压器将之输出电压启动斜坡由软启动引脚控制,该引脚还可被配置用来控制定序/跟踪。一个开漏电源正常信号表示输出处于标称电压值的93%至106%之内。
宽可调开关频率范围可针对效率或者外部组件尺寸进行优化。逐周期电流限制,频率折返和热关断在过载条件下保护内部和外部组件。
TPS54341器件采用10引脚4mm x 4mm SON封装。
<小> 小>
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54341 | TPS54040A | TPS54140A | TPS54240 | TPS54340 | TPS54540 | TPS54541 |
| 4.5 | 3.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 |
| 42 | 42 | 42 | 42 | 42 | 42 | 42 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 41 | 39 | 39 | 39 | 41 | 41.1 | 41 |
| 3.5 | 0.5 | 1.5 | 2.5 | 3.5 | 5 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.152 | 0.116 | 0.116 | 0.138 | 0.146 | 0.146 | 0.152 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| WSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | SO PowerPAD | SO PowerPAD | WSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
