数据:
TPS53915 具有 PMBus™ 接口的 1.5V 至 18V(4.5V 至 25V 偏置)输入、12A 同步降压 SWIFT™ 转换器 数据表 (Rev. B)
TPS53915是一款具有自适应接通时间D-CAP3控制模式的小尺寸,同步降压转换器。此器件使空间受限电源系统易于使用,并且外部组件数量较少。
该器件特有高性能集成MOSFET,精度为0.5%的0.6V电压基准和一个集成的升压开关。具有竞争力的特性包括:极低外部组件数量,快速负载瞬态响应,自动跳跃模式操作,内部软启动控制,并且无需补偿。此外,该器件还具备可编程性和故障报告特性,这些特性通过PMBus实现,以简化电源设计。
强制持续传导模式有助于满足数字信号处理器(DSP)和现场可编程门阵列(FPGA)性能实现所要求的严格电压调节精度.TPS53915采用28引脚QFN封装,并且在-40°C至85°C的环境温度范围内额定运行。
所有商标均为其各自的商标。拥有者。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS53915 | TPS53513 | TPS53515 | TPS54020 | TPS548A20 | TPS549A20 |
| 1.5 | 1.5 | 1.5 | 4.5 | 4.5 | 4.5 |
| 18 | 18 | 18 | 17 | 20 | 20 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
| 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 |
| 12 | 8 | 12 | 10 | 15 | 15 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 250 | 250 | 250 | 200 | 250 | 250 |
| 1000 | 1000 | 1000 | 1200 | 1000 | 1000 |
| 1.35 | 1.35 | 1.35 | 0.6 | 1.35 | 1.35 |
| Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable Voltage Margining |
| D-CAP3 | D-CAP3 | D-CAP3 | Current Mode | D-CAP3 | D-CAP3 |
| 80 | 80 | 80 | 98 | 50 | 50 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 150 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN-CLIP | VQFN-CLIP | VQFN-CLIP | VQFN-HR | VQFN-CLIP | VQFN-CLIP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
