数据:
TPS6218x 4V 至 15V、6A、双相降压转换器,具有 AEE 数据表 (Rev. B)
TPS6218x是一款适用于薄型电源轨的双相降压DC-DC转换器。它采用峰值电流控制且两相电流平衡,适合高度受限的应用。
该器件具有4V到15V的宽工作输入电压范围,非常适合通过多节锂离子电池或12V电源轨供电运行的系统。两相可持续提供6A输出电流(每相3A),从而允许使用薄型外部元件。两相异相运行,这样可显着减小开关噪声。
TPS6218x可在超轻负载时自动进入节能模式以保持高效率,并且还集成有自动效率提高功能( AEE™),适用于整个占空比范围。
该器件支持电源正常信号和可调软启动。其静态电流典型值为28μA,并且能够在100%模式下运行,即便在最低输出电压下也不存在占空比限制。
TPS6218x提供了可调节输出电压和固定输出电压两种选项,并且采用24凸点,0.5mm间距的小型DSBGA封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62180 | TPS62095 | TPS62130 | TPS62136 | TPS62140 | TPS62150 | TPS62182 | TPS62480 |
| 4 | 2.5 | 3 | 3 | 3 | 3 | 4 | 2.4 |
| 15 | 5.5 | 17 | 17 | 17 | 17 | 15 | 5.5 |
| 0.9 | 0.8 | 0.9 | 0.8 | 0.9 | 0.9 | 3.3 | 0.6 |
| 6 | 5.5 | 6 | 12 | 6.3 | 6.3 | 3.3 | 5.5 |
| 6 | 4 | 3 | 4 | 2 | 1 | 6 | 6 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 1000 | 1400 | 1250 | 1000 | 1250 | 1250 | 1000 | 2000 |
| 2000 | 1400 | 2500 | 1000 | 2500 | 2500 | 2000 | 2500 |
| 0.03 | 0.02 | 0.017 | 0.018 | 0.017 | 0.017 | 0.03 | 0.023 |
| Enable Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Tracking Voltage Margining | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Multiple Outputs Phase Interleaving Power Good Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining |
| Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Current Mode |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| DSBGA | VQFN | VQFN | VQFN-HR | VQFN | VQFN | DSBGA | VQFN-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
