数据:
具有电压调节功能 TPS56x20 4.5V 至 17V 输入、12A/9A/7A/5A 输出、同步降压电压稳压器 数据表 (Rev. E)
TPS56X20一款同步直流 - 直流转换器IC(集成电路),此转换器具有电压调节控制功能,以便为要求内核电压(V < sub> CORE )调整的微处理器(MCU)供电。最初加电后,输出电压可由I 2 C兼容总线上发送的VID代码编程/调节。
这个降压转换器采用一个自适应接通时间D-CAP2模式控制,此模式控制在无需外部组件的情况下提供极快的瞬态响应。与传统的电压/电流模式控制不同, D-CAP2支持较高负载下的PWM模式与轻负载情况下的Eco-mode™模式之间的无缝转换.Eco-mode在轻负载时保持高效率。
TPS56X20支持超低ESR陶瓷电容器和低等效串联电阻(ESR)输出电容器,诸如高分子钽固体电解电容器(POSCAP)或高分子聚合物电容器(SP-CAP)。此器件针对小尺寸1.0μH至2.2μH电感器进行了优化,节省了印刷电路板(PCB)面积。
TPS56X20器件采用HTSSOP封装。
所有商标均为他们各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS56520 | TPS51362 | TPS53318 | TPS53319 | TPS53353 | TPS53355 | TPS566250 | TPS56628 | TPS56720 | TPS56920 | TPS56C20 |
| 4.5 | 3 | 1.5 | 1.5 | 1.5 | 1.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 17 | 22 | 22 | 22 | 15 | 15 | 17 | 18 | 17 | 17 | 17 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.76 | 0.6 | 0.6 | 0.6 |
| 1.87 | 2 | 5.5 | 5.5 | 5.5 | 5.5 | 1.87 | 5.5 | 1.87 | 1.87 | 1.87 |
| 5 | 10 | 8 | 14 | 20 | 30 | 6 | 6 | 7 | 9 | 12 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 500 | 800 | 250 | 250 | 250 | 250 | 500 | 650 | 500 | 500 | 500 |
| 500 | 800 | 1000 | 1000 | 1000 | 1000 | 500 | 650 | 500 | 500 | 500 |
| 0.92 | 0.1 | 0.32 | 0.32 | 0.32 | 0.32 | 0.9 | 0.95 | 0.92 | 0.92 | 0.92 |
| Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining |
| D-CAP2 | D-CAP2 | D-CAP | D-CAP | D-CAP | D-CAP | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 80 | 87 | 90 | 90 | 90 | 90 | 80 | 85 | 80 | 80 | 80 |
| -40 to 85 | -10 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP | VQFN-CLIP | LSON-CLIP | LSON-CLIP | LSON-CLIP | LSON-CLIP | SO PowerPAD | SO PowerPAD | HTSSOP | HTSSOP | HTSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
