数据:
TPS6100x Single- and Dual-Cell Boost Converter
With Start-up Into Full Load 数据表
TPS6100x器件是升压转换器,适用于通常采用单节或双节镍镉(NiCd),镍氢电池供电的系统(NiMH),或碱性电池。转换器输出电压可在1.5 V至最大3.3 V范围内调节,单个电池单元的最小输出电流为100 mA,两个电池单元的最小输出电流为250 mA。转换器在电源电压为0.9 V的情况下启动至满负载,并在电源电压低至0.8 V的情况下保持工作状态。
转换器基于固定频率,电流模式脉冲 - 宽度调制(PWM)控制器,在低负载电流下进入省电模式。通过开关的电流限制为最大1100 mA,具体取决于输出电压。集成了电流感,以进一步减少外部元件数量。当系统进入待机状态时,可以禁用转换器以最大限度地减少电池消耗。
实现低EMI模式以减少电感器在电感器振铃时引起的干扰和辐射电磁能量放电电流降至零。该器件采用节省空间的10引脚MSOP封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Switch Current Limit (Typ) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS61000 | TPS61002 | TPS61005 | TPS61006 | TPS61007 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 3.3 | 1.8 | 3 | 3.3 | 3.3 |
| 1.5 | 1.8 | 3 | 3.3 | 1.5 |
| 1.1 | 0.65 | 1 | 1.1 | 1.1 |
| 1 | 1 | 1 | 1 | 1 |
| 360 | 360 | 360 | 360 | 360 |
| 840 | 840 | 840 | 840 | 840 |
| 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
| Enable Light Load Efficiency Power Good | Enable Light Load Efficiency Power Good | Enable Light Load Efficiency Power Good | Enable Light Load Efficiency Power Good | Enable Light Load Efficiency Power Good |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VSSOP | VSSOP | VSSOP | VSSOP | VSSOP |
| 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
