数据:
TPS62480 2.4V 至 5.5V、6A、双相降压转换器 数据表 (Rev. A)
TPS62480是一款适用于薄型负载点电源的同步双相降压DC-DC转换器。此器件的输入电压范围为2.4V至可输出电流最高可达6A(由两相持续提供,每相3A),从而允许使用薄型外部组件。两条电源轨异相运行,可显着降低脉冲电流噪声。
TPS62480可在超轻负载时自动进入节能模式以保持高效率。其中包含自动增加/减少相位功能,具体使用一个相位还是两个相位视实际负载情况而定。
该器件具有电源正常信号和可调节的软启动功能。此外,该器件还具有热性能正常信号,用以检测内部温度是否过高。通过VSEL引脚可输出电压更改为预选值.TPS62480能够在100%占空比模式下工作。
TPS62480采用小型3mm×2.5mm HotRod封装(RNC)。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62480 | TLV62084A | TLV62085 | TLV62095 | TLV62569 | TPS62080 | TPS62085 | TPS62088 | TPS62090 | TPS62095 | TPS62097 | TPS62136 | TPS62180 | TPS62801 | TPS62802 | TPS62806 | TPS62823 | TPS62825 | TPS62826 |
| 2.4 | 2.7 | 2.5 | 2.5 | 2.5 | 2.3 | 2.5 | 2.4 | 2.5 | 2.5 | 2.5 | 3 | 4 | 1.8 | 1.8 | 1.8 | 2.4 | 2.4 | 2.4 |
| 5.5 | 6 | 6 | 5.5 | 5.5 | 6 | 6 | 5.5 | 6 | 5.5 | 6 | 17 | 15 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 0.6 | 0.5 | 0.8 | 0.8 | 0.6 | 0.5 | 0.8 | 0.6 | 0.8 | 0.8 | 0.8 | 0.8 | 0.9 | 0.8 | 1.8 | 0.4 | 0.6 | 0.6 | 0.6 |
| 5.5 | 4 | 6 | 5.5 | 5.5 | 4 | 6 | 4 | 6 | 5.5 | 6 | 12 | 6 | 1.55 | 3.3 | 0.775 | 4 | 4 | 4 |
| 6 | 2 | 3 | 4 | 2 | 1.2 | 3 | 3 | 3 | 4 | 2 | 4 | 6 | 1 | 1 | 0.6 | 3 | 2 | 3 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2000 | 2000 | 2400 | 1400 | 1500 | 2000 | 2400 | 4000 | 1400 | 1400 | 1500 | 1000 | 1000 | 4000 | 4000 | 1500 | 2200 | 2200 | 2200 |
| 2500 | 2000 | 2400 | 1400 | 1500 | 2000 | 2400 | 4000 | 2800 | 1400 | 2500 | 1000 | 2000 | 4000 | 4000 | 1500 | 2200 | 2200 | 2200 |
| 0.023 | 0.03 | 0.017 | 0.02 | 0.035 | 0.0065 | 0.017 | 0.004 | 0.02 | 0.02 | 0.04 | 0.018 | 0.03 | 0.0023 | 0.0023 | 0.0023 | 0.004 | 0.004 | 0.004 |
| Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Load Disconnect Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Enable Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Load Disconnect Output Discharge Over Current Protection Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Fixed |
| Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Current Mode | Constant on-time (COT) DCS-Control | DCS-Control | DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN-HR | WSON | VSON-HR | VQFN | SOT-23 SOT-23-THIN SOT-5X3 | WSON | VSON-HR | DSBGA | VQFN | VQFN | VQFN-HR | VQFN-HR | DSBGA | DSBGA | DSBGA | DSBGA | VSON-HR | VSON-HR | VSON-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
