数据:
LM53600/01-Q1 0.65A/1A、36V 同步、2.1MHz、汽车类降压 DC-DC 转换器 数据表 (Rev. B)
LM53600-Q1和LM53601-Q1同步降压稳压器针对汽车应用进行了优化,可提供5V,3.3V或可调节输出三种输出电压.LM53600-Q1支持高达650mA的负载电流,而LM53601-Q1支持高达1000mA的负载电流.LM53600-Q1和LM53601-Q1器件可利用高级高速电路在2.1HMz的固定频率下实现从18V输入到3.3 V输出的稳压。这两款器件采用创新型架构,在输入电压仅为3.8V时也可提供3.3V稳压输出。输入电压最高可达36V,容许的最高瞬态电压达42V,这简化了输入浪涌保护设计。开漏复位输出具有滤波和延迟释放功能,可提供正确的系统状态指示。凭借这一特性,器件无需使用附加监控组件,这节省了成本和电路板空间。这两款器件可在PWM和脉频调制(PFM)两种模式之间无缝切换,并且静态电流仅为23μA,这确保了其在所有负载条件下均可展现高效率和出色的瞬响应。外部组件需求的降低使得器件的印刷电路板(PCB)布局更加紧凑。尽管LM53600-Q1和LM53601-Q1器件属于Q1级,但均可在-40°C至150°C的结温范围内保证电气特性。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM53601-Q1 | LM26001-Q1 | LM26003-Q1 | LM53600-Q1 | LM53602-Q1 | LM53603-Q1 | LM53625-Q1 | LMS3635-Q1 | LMS3655-Q1 |
| 3.5 | 3 | 3 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| 42 | 38 | 38 | 42 | 42 | 42 | 42 | 42 | 42 |
| 3.2 | 1.25 | 1.25 | 3.3 | 3.2 | 3.2 | 3.2 | 1 | 1 |
| 6 | 35 | 35 | 9.9 | 9.9 | 9.9 | 10 | 15 | 15 |
| 1 | 1.5 | 3 | 0.65 | 2 | 3 | 2.5 | 3.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 1890 | 150 | 150 | 1890 | 1850 | 1850 | 1850 | 250 | 250 |
| 2400 | 500 | 500 | 2400 | 2350 | 2350 | 2350 | 500 | 500 |
| 0.023 | 0.038 | 0.04 | 0.023 | 0.023 | 0.023 | 0.018 | 0.015 | 0.015 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Pre-Bias Start-Up | Enable Light Load Efficiency Power Good Pre-Bias Start-Up | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Wettable Flanks Package | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Spread Spectrum Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 150 | -40 to 125 | -40 to 125 | -40 to 150 | -40 to 150 | -40 to 150 | -40 to 150 | -40 to 150 | -40 to 150 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| WSON | HTSSOP | HTSSOP | WSON | HTSSOP | HTSSOP | VQFN-HR | VQFN-HR | VQFN-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
