数据:
TPS51275B-1 具有 5V 和 3.3V LDO 的双路同步降压控制器 数据表
TPS51275B-1器件是一款面向笔记本系统电源解决方案的经济实用型双路同步降压控制器。该器件具有5V和3.3V低压降稳压器,只需要很少的外部元件。该器件可使用260kHz VCLK输出来驱动外部电荷泵,从而为负载开关生成栅极驱动电压,并且不会降低主转换器的效率.TPS51275B-1兼容高效率和快速瞬态响应优势,同时可提供组合式电源正常信号。自适应导通时间D-CAP控制方案可确保器件的运行方便而高效。器件的电源输入电压范围为5V至24V,并且支持5V和3.3V两种输出电压.TPS51275B-1器件采用20引脚3mm×3mm WQFN封装,额定温度范围为-40°C至85°C。
所有商标均为p他们各自所有者的roperty。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS51275B-1 | TPS51225B | TPS51225C | TPS51275B | TPS51285A | TPS51285B |
| 5 | 5.5 | 5.5 | 5 | 5 | 5 |
| 24 | 24 | 24 | 24 | 24 | 24 |
| 4.85 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 5.1 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 20 | 10 | 10 | 20 | 20 | 20 |
| 2 | 2 | 2 | 4 | 2 | 2 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 300 | 300 | 300 | 300 | 400 | 400 |
| 355 | 355 | 355 | 355 | 475 | 475 |
| 0.8 | 0.9 | 0.9 | 0.8 | 0.084 | 0.084 |
| Enable Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification |
| 95 | 90 | 90 | 95 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| WQFN | WQFN | WQFN | WQFN | WQFN | WQFN |
| D-CAP | D-CAP | D-CAP | D-CAP | ||
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
