数据:
TPS548A20 具有 PMBus™ 接口的 1.5V 至 20V(4.5V 至 25V 偏置)输入、15A 同步降压 SWIFT™ 转换器 数据表 (Rev. A)
TPS548A20是一款具有自适应导通时间D-CAP3控制模式的小尺寸同步降压转换器。此器件使得空间受限类电源系统易于使用,并且外部组件数量较少。
此器件特有高性能集成MOSFET,精准0.6V基准和一个集成的升压开关。具有竞争力的特性包括:极低外部组件数量,快速负载瞬态响应,自动跳跃模式操作,内部软启动控制,并且无需补偿。
强制持续传导模式有助于满足高性能DSP和FPGA应用的严格电压调节精度要求.TPS548A20采用28引脚VQFN-CLIP封装,并且在-40°C至125°C的环境温度范围内额定运行。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS548A20 | TPS53513 | TPS53515 | TPS53915 | TPS549A20 |
| 4.5 | 1.5 | 1.5 | 1.5 | 4.5 |
| 20 | 18 | 18 | 18 | 20 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 15 | 8 | 12 | 12 | 15 |
| 1 | 1 | 1 | 1 | 1 |
| 250 | 250 | 250 | 250 | 250 |
| 1000 | 1000 | 1000 | 1000 | 1000 |
| 1.35 | 1.35 | 1.35 | 1.35 | 1.35 |
| Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification Voltage Margining | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable Voltage Margining |
| D-CAP3 | D-CAP3 | D-CAP3 | D-CAP3 | D-CAP3 |
| 50 | 80 | 80 | 80 | 50 |
| -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN-CLIP | VQFN-CLIP | VQFN-CLIP | VQFN-CLIP | VQFN-CLIP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
