数据:
TPS62135、TPS621351 高精度、3V 至 17V、4A 降压转换器(采用 DCS-Control) 数据表 (Rev. B)
TPS62135和TPS621351是高效且易于使用的同步降压DC-DC转换器,基于DCS-控制™拓扑技术。器件具有3V至17V的宽输入电压范围,非常适合由多节锂离子电池以及12V中间电源轨供电的应用。该器件提供图4A连续输出电流.TPS62135可以在轻载时自动进入节能模式,从而可在整个负载范围内保持高效率。因此,器件非常适合要求联网待机性能的应用,例如,超低功耗计算机。如果将MODE引脚设置为低电平,那么器件的开关频率会基于输入输出电压自动调整。该技术称为自动效率提高(AEE™),可以在整个运行范围内保持高转换效率。器件可以在PWM模式下提供1%的输出电压精度,因此可实现具有高输出电压精度的电源设计。
< p>器件的典型静态电流为18μA。在关断模式下,器件电流典型值为1μA,输出主动放电(仅适用于TPS62135,TP S621351的输出电压放电功能被禁用)。TPS62135作为一个可调版本提供,采用3mm x 2mm VQFN封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62135 | TPS621351 | TPS62136 | TPS62140 | TPS62147 | TPS62148 |
| 3 | 3 | 3 | 3 | 3 | 3 |
| 17 | 17 | 17 | 17 | 17 | 17 |
| 0.8 | 0.8 | 0.8 | 0.9 | 0.8 | 0.8 |
| 12 | 12 | 12 | 6.3 | 12 | 12 |
| 4 | 4 | 4 | 2 | 2 | 2 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 2500 | 2500 | 1000 | 1250 | 1250 | 1250 |
| 2500 | 2500 | 1000 | 2500 | 2500 | 2500 |
| 0.018 | 0.018 | 0.018 | 0.017 | 0.018 | 0.018 |
| Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: other | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: other | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed VID: 2-bit | Enable Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Fixed Voltage Margining | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Output Discharge Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | DCS-Control | DCS-Control |
| 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| VQFN-HR | VQFN-HR | VQFN-HR | VQFN | VQFN-HR | VQFN-HR |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
