数据:
TPS549D22 1.5V 至 16V
VIN、4.5V 至 22V VDD、40A 且具有全差分感应功能和PMBus的
SWIFT™ 同步降压转换器 数据表 (Rev. A)
TPS549D22器件是一款紧凑型单通道降压转换器,具有自适应导通时间D-CAP3模式控制。该器件专为高精度,高效率,快速瞬态响应,易于使用,外部组件较少且空间受限的电源系统而设计。
该器件采用全差分感应和TI集成FET,高侧导通电阻为2.9mΩ,低侧导通电阻为1.2mΩ。此外,该器件还具有0.5%的精度和0.9V基准电压,环境温度范围介于-40°C和+ 125°C之间。其竞争优势包括:极少的外部组件数,精确的负载调节和线路调节,自动跳跃或FCCM工作模式以及内部软启动控制。
TPS549D22器件采用7mm×5mm,40引脚,LQFN-CLIP(RVF) )封装(RoHs豁免)。
< small>所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS549D22 | TPS53355 | TPS548B22 | TPS548D21 | TPS548D22 | TPS549B22 | TPS56121 |
| 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 4.5 |
| 16 | 15 | 18 | 16 | 16 | 18 | 14 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 12 |
| 40 | 30 | 25 | 40 | 40 | 25 | 15 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 315 | 250 | 425 | 425 | 425 | 315 | 300 |
| 1125 | 1000 | 1050 | 1050 | 1050 | 1125 | 1000 |
| 2 | 0.32 | 2 | 2 | 2 | 2 | 2.5 |
| Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Output Discharge Over Current Protection PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Power Good Pre-Bias Start-Up Synchronous Rectification |
| D-CAP3 | D-CAP | D-CAP3 | D-CAP3 | D-CAP3 | D-CAP3 | Voltage Mode |
| 80 | 90 | 80 | 80 | 80 | 80 | 93 |
| -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| LQFN-CLIP | LSON-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LSON-CLIP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
