数据:
bq78z100 Impedance Track 用于 1 节和 2 节串联锂离子/锂聚合物电池组的电量监测计 数据表
bq78z100器件提供了一套基于电池组的全集成解决方案,其具有闪存可编程的定制精简指令集CPU(RISC),安全保护以及认证功能,适用于1节和2节锂离子和锂聚合物电池组。
bq78z100电量监测计通过I 2 C兼容接口或单线制HDQ接口进行通信,并将超低功耗的高速德州仪器(TI)bqBMP处理器,高精度模拟测量功能,集成闪存,大量的外设和通信端口,N沟道FET驱动器以及SHA-1认证转换响应器完美融合于一套完整的高性能电池管理解决方案。
bq78z100器件提供有大量的电池和系统安全功能,其中包括针对电池的放电过流,充电短路和放电短路功能,针对N沟道FET的FET保护,内部AFE看门狗以及电池平衡功能。该器件可通过固件添加更多保护特性,例如过压,欠压,过热等。
所有商标均为其各自所有者的财产。
| Number of Series Cells |
| Cell Chemistry |
| Battery Capacity (Max) (mAh) |
| Communication Interface |
| Battery Capacity (Min) (mAh) |
| External Capacity Indication |
| Implementation |
| Gas Gauge Algorithm |
| Cell Balancing |
| Features |
| Operating Temperature Range (C) |
| Pin/Package |
| BQ78Z100 | BQ27542-G1 | BQ27750 | BQ28Z610 | BQ4050 | BQ40Z50-R1 | BQ78350-R1 |
| 1-2 Cells | Single Cell | Single Cell | 1-2 Cells | 2-4 Cells Single Cell | 2-4 Cells Single Cell | >4 Cells |
| Li-Ion/Li-Polymer | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer LiFePO4 | Li-Ion/Li-Polymer LiFePO4 |
| 14000 | 32000 | 14000 | 14000 | 29000 | 29000 | 320000 |
| HDQ | HDQ I2C | I2C | I2C | SMBus | SMBus | I2C SMBus |
| 100 | 100 | 100 | 100 | 500 | 100 | 100 |
| None | None | None | None | LED | LED | LCD LED SOC |
| Pack | Pack | Pack | Pack | Pack | Pack | Pack |
| Impedance Track | Impedance Track | Impedance Track | Impedance Track | CEDV | Impedance Track | CEDV |
| External Internal | N/A | N/A | External Internal | External Internal | External Internal | External Internal |
| Cell Balancing Integrated Protector SHA-1 Authentication | SHA-1 Authentication | Accumulated Coulomb Count Battery Management Unit Integrated Protector SHA-1 Authentication | Battery Management Unit Cell Balancing Integrated Protector SHA-1 Authentication | Cell Balancing Integrated Protector SHA-1 Authentication | Cell Balancing Integrated Protector SHA-1 Authentication Turbo Mode | Cell Balancing Integrated Protector SHA-1 Authentication |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| 12SON | 12SON | 12SON | 12SON | 32VQFN | 32VQFN | 30TSSOP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
