数据:
具有 64 字节 FIFO 的 TL16C752C 双路 UART 数据表 (Rev. C)
TL16C752C是一款双路通用异步收发器(UART),具有64字节先入先出(FIFO)以及自动硬件和软件流控制功能,数据传输速率最高可达3Mbps。该器件具备增强功能的磁场感测解决方案。该器件具有一个传输字符控制寄存器(TCR),可存储接收到的FIFO阈值电平,用于在硬件和软件流控制过程中启动或停止传输。
凭借FIFO RDY寄存器,软件只需执行单次访问即可获得两个端口的TXRDY或RXRDY状态。片上状态寄存器可为用户提供错误指示,运行状态以及调制解调器接口控制。可根据用户要求定制系统中断。内部环回功能支持板上诊断.TL16C752C整合了两个UART的功能,每个UART具备各自的寄存器集和FIFO。两个UART只共享数据总线接口和时钟源,除此之外都是独立运行的.UART功能也称作异步通信元件(ACE),这两个术语可以互使用。本文档要介绍每个ACE的行为,并让读者了解到TL16C752C器件中整合了这两个ACE。
所有商标均为各自所有者的财产。
| Number of Channels (#) |
| FIFOs (bytes) |
| Rx FIFO Trigger Levels (#) |
| Tx FIFO Trigger Levels (#) |
| Programmable FIFO Trigger Levels |
| CPU Interface |
| Baud Rate (max) at Vcc = 1.8V and with 16X Sampling (Mbps) |
| Baud Rate (max) at Vcc = 2.5V and with 16X Sampling (Mbps) |
| Baud Rate (max) at Vcc = 3.3V and with 16X Sampling (Mbps) |
| Baud Rate (max) at Vcc = 5.0V and with 16X Sampling (Mbps) |
| Operating Voltage (V) |
| Auto RTS/CTS |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| TL16C752C | NS16C2752 | TL16C2752 | TL16C750 | TL16C752B-EP | TL16C752CI-Q1 | TL16C752D | TL16C752D-Q1 | TL16C754C |
| 2 | 2 | 2 | 1 | 2 | 2 | 2 | 2 | 4 |
| 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
| 16 | 4 | 4 | 4 | 16 | 16 | 16 | 16 | 16 |
| 16 | 4 | 4 | N/A | 16 | 16 | 16 | 16 | 16 |
| Yes | No | Yes | No | Yes | Yes | Yes | Yes | Yes |
| X86 | X86 | X86 | X86 | X86 | X86 | X86 | X86 | X86 |
| 1 | N/A | 1 | N/A | N/A | 1 | 1 | 1 | 1 |
| 1.5 | N/A | 1.5 | N/A | N/A | 1.5 | 1.5 | 1.5 | 1.5 |
| 2 | 5 | 2 | 0.875 | 3 | 2 | 2 | 2 | 2 |
| 3 | 5 | 3 | 1 | N/A | 3 | 3 | 3 | 3 |
| 1.8 2.5 3.3 5 | 3.3 5 | 1.8 2.5 3.3 5 | 3.3 5 | 3.3 | 1.8 2.5 3.3 5 | 1.62 to 5.5 | 1.62 to 5.5 | 1.8 2.5 3.3 5 |
| Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| Catalog | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | Automotive | Catalog |
| 0 to 70 -40 to 85 | -40 to 85 | -40 to 85 0 to 70 | 0 to 70 | -40 to 105 -40 to 110 -55 to 110 | -40 to 105 | 0 to 70 | -40 to 105 | -40 to 85 0 to 70 |
| TQFP VQFN | PLCC TQFP | PLCC | LQFP PLCC | LQFP | TQFP | TQFP | TQFP | LQFP |
| 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
