TSB41AB1 IEEE 1394a 一端口电缆收发器/仲裁器
KANA 发表于 2018-10-16 11:16:58
数据: IEEE 1394a-2000 One-Port Cable Transceiver/Arbiter 数据表
The TSB41AB1 provides the digital and analog transceiver functions needed to implement a one-port node in a cable-based IEEE 1394 network. The cable port incorporates one differential line transceiver. The transceiver includes circuitry to monitor the line conditions as needed for determining connection status, for initialization and arbitration, and for packet reception and transmission. The TSB41AB1 is designed to interface with a link layer controller (LLC), such as the TSB12LV21, TSB12LV22, TSB12LV23, TSB12LV26, TSB12LV31, TSB12LV41, TSB12LV42, or TSB12LV01A.
The TSB41AB1 requires only an external 24.576-MHz crystal as a reference. An external clock may be provided instead of a crystal. An internal oscillator drives an internal phase-locked loop (PLL), which generates the required 393.216-MHz reference signal. This reference signal is internally divided to provide the clock signals used to control transmission of the outbound encoded strobe and data information. A 49.152-MHz clock signal is supplied to the associated LLC for synchronization of the two chips and is used for resynchronization of the received data. The power-down (PD) function, when enabled by asserting the PD terminal high, stops operation of the PLL.
The TSB41AB1 supports an optional isolation barrier between itself and its LLC. When the ISO\ input terminal is tied high, the LLC interface outputs behave normally. When the ISO\ terminal is tied low, internal differentiating logic is enabled, and the outputs are driven such that they can be coupled through a capacitive or transformer galvanic isolation barrier as described in Annex J of IEEE Std 1394-1995 and in IEEE 1394a-2000 (section 5.9.4) (hereinafter referred to as Annex J type isolation). To operate with TI bus holder isolation the ISO\ terminal on the PHY must be high.
Data bits to be transmitted through the cable port are received from the LLC on two, four or eight parallel paths (depending on the requested transmission speed) and are latched internally in the TSB41AB1 in synchronization with the 49.152-MHz system clock. These bits are combined serially, encoded, and transmitted at 98.304, 196.608, or 393.216 Mbits/s (referred to as S100, S200, and S400 speeds, respectively) as the outbound data-strobe information stream. During transmission, the encoded data information is transmitted differentially on the TPB cable pair, and the encoded strobe information is transmitted differentially on the TPA cable pair.
During packet reception the TPA and TPB transmitters of the receiving cable port are disabled, and the receivers for that port are enabled. The encoded data information is received on the TPA cable pair, and the encoded strobe information is received on the TPB cable pair. The received data-strobe information is decoded to recover the receive clock signal and the serial data bits. The serial data bits are split into two-, four-, or eight-bit parallel streams (depending upon the indicated receive speed), resynchronized to the local 49.152-MHz system clock and sent to the associated LLC.
Both the TPA and TPB cable interfaces incorporate differential comparators to monitor the line states during initialization and arbitration. The outputs of these comparators are used by the internal logic to determine the arbitration status. The TPA channel monitors the incoming cable common-mode voltage. The value of this common-mode voltage is used during arbitration to set the speed of the next packet transmission. In addition, the TPB channel monitors the incoming cable common-mode voltage on the TPB pair for the presence of the remotely supplied twisted-pair bias voltage.
The TSB41AB1 provides a 1.86-V nominal bias voltage at the TPBIAS terminal for port termination. This bias voltage, when seen through a cable by a remote receiver, indicates the presence of an active connection. This bias voltage source must be stabilized by an external filter capacitor of 1 µF. TPBIAS is typically VDD–0.2 V when the port is not connected to another node.
The line drivers in the TSB41AB1 operate in a high-impedance current mode, and are designed to work with external 112- resistors. The midpoint of the pair of resistors that is directly connected to the twisted-pair-A terminals is connected to its corresponding TPBIAS voltage terminal. The midpoint of the pair of resistors that is directly connected to the twisted-pair-B terminals is coupled to ground through a parallel R-C network with recommended values of 5 k±1.0%.
When the power supply of the TSB41AB1 is off while the twisted-pair cables are connected, the TSB41AB1 transmitter and receiver circuitry presents a high impedance to the cable and does not load the TPBIAS voltage at the other end of the cable. Fail-safe circuitry blocks any leakage path from the port back to the device power plane.
The TESTM, SE, and SM terminals are used to set up various manufacturing test conditions. For normal operation, the TESTM terminal should be connected to VDD through a 1-k resistor, and SM should be connected directly to ground.
Four package terminals are used as inputs to set the default value for four configuration status bits in the self-ID packet, and are tied high through a 1-k
特性
  • 完全支持IEEE 1394-1995高性能串行总线标准的规定??和IEEE 1394a-2000
  • 完全可与FireWire™和i.LINK™实施IEEE Std 1394完全互操作
  • 完全符合OpenHCI要求
  • 提供一个IEEE 1394a -2000完全兼容的电缆端口,100/200兆比特每秒(Mbits /s)
  • 完整的IEEE 1394a-2000支持包括:连接去抖,仲裁短复位,多速连接,仲裁加速,飞 - 通过级联,端口禁用/挂起/恢复
  • 寄存器位为竞争器位,电源类位,链路活动控制位和IEEE 1394a-2000功能提供软件控制
  • IEEE 1394a传入TPBIAS上的2000兼容共模噪声滤波器
  • 扩展恢复信令,与传统DV设备兼容,与TSB41LV01兼容,允许直接等时传输到具有任何链路层的传统DV设备Root
  • 用于节省电池供电应用的节能特性包括:Autom暂停期间设备掉电,设备掉电终端,通过LPS禁用链路接口,以及非活动端口断电
  • 故障安全电路检测到设备突然断电并禁用端口以确保设备不加载连接设备的TPBIAS并阻止从端口返回设备电源层的任何泄漏路径
  • 软件设备重置(SWR)
  • 行业领先的低功耗
  • 超低功耗睡眠模式
  • 有线电源存在监控
  • 电缆端口监控有线连接到远程节点的线路条件
  • 数据接口到链路 - 层控制器通过49.152 MHz的2/4/8并行线
  • 链路层控制器接口支持低成本TI总线保持器隔离和可选附件J电气隔离
  • 可与链路互操作 - 层控制器使用3.3 V
  • 单3.3 V电源操作
  • 低成本24.576 MHz晶振提供发送,接收数据速率为100/200/400 Mbits /s,链路层控制器时钟频率为49.152 MHz
  • 低成本高性能48/64引脚TQFP(PHP /PAP)热增强型封装可提高散热性能高达210%
  • 符合英特尔®移动电源指南2000
  • 采用80球MicroStar Junior™BGA(GQE)封装提供
  • 64-球,无铅,MicroStar Junior™BGA(ZQE)封装
FireWire是Apple Computer,Incorporated的商标。
i.LINK是Sony Kabushiki的商标。 Kaisha TA Sony Corporation。
Intel是Intel Corporation的商标。
其他商标是其各自所有者的财产。
MicroStar Junior是德州仪器公司的商标。
查看更多内容
参数 与其它产品相比 其他接口
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Pin/Package
TSB41AB1
0 to 70
BGA MICROSTAR JUNIOR
HTQFP
HTQFP
64BGA MICROSTAR JUNIOR: 25 mm2: 5 x 5(BGA MICROSTAR JUNIOR)
80BGA MICROSTAR JUNIOR: 25 mm2: 5 x 5(BGA MICROSTAR JUNIOR)
48HTQFP: 81 mm2: 9 x 9(HTQFP)
64HTQFP: 144 mm2: 12 x 12(HTQFP)
48HTQFP
64HTQFP
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
