数据:
TPD1E01B04 适用于 USB Type-C 和 Thunderbolt 3 的单通道 ESD 保护二极管 数据表 (Rev. B)
TPD1E01B04是一款适用于USB Type-C和Thunderbolt 3电路保护的双向TVS ESD保护二极管阵列.TPD1E01B04的额定ESD冲击消散值等于IEC 61000-4-2(4级)国际标准中规定的最高水平。
此器件特有一个0.18pF(典型值)IO电容,适用于保护速率高达20Gbps的高速接口(例如USB 3.1) Gen2和Thunderbolt 3)。低动态电阻和低钳位电压可针对瞬变事件提供系统级保护。
TPD1E01B04采用符合工业标准的0201(DPL)封装。
所有商标均为各自所有者的财产。
| Number of Channels (#) |
| IO Capacitance (Typ) (pF) |
| Breakdown Voltage (Min) (V) |
| IEC 61000-4-2 Contact (+/- kV) |
| IEC 61000-4-2 Air-Gap (+/- kV) |
| Interface |
| Features |
| Bi-/Uni-Directional |
| IO Leakage Current (Max) (nA) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Dynamic Resistance (Typ) (Ω) |
| Clamping Voltage (V) |
| Pin/Package |
| TPD1E01B04 | ESD122 | ESD224 | TPD1E04U04 | TPD1E05U06 | TPD1E0B04 | TPD1E10B06 | TPD1E1B04 | TPD1E6B06 | TPD4E02B04 | TPD4E05U06 |
| 1 | 2 | 4 | 1 | 1 | 1 | 1 | 1 | 1 | 4 | 4 |
| 0.18 | 0.2 | 0.5 | 0.5 | 0.4 | 0.13 | 12 | 1 | 6 | 0.25 | 0.5 |
| 6.4 | 5.1 | 6.2 | 5 | 6.5 | 6.7 | 6 | 6.4 | 6 | 5.5 | 6.5 |
| 15 | 18 | 12 | 16 | 12 | 8 | 30 | 30 | 15 | 12 | 12 |
| 17 | 18 | 15 | 16 | 15 | 9 | 30 | 30 | 15 | 15 | 15 |
| HDMI 1.4/1.3 HDMI 2.0 USB 3.0 USB Type-C | HDMI 1.4/1.3 HDMI 2.0 SATA/PCIe USB 2.0 USB 3.0 USB Type-C | HDMI 1.4 HDMI 1.4/1.3 HDMI 2.0 USB 2.0 USB 3.0 USB Type-C | HDMI 1.4/1.3 HDMI 2.0 USB 2.0 USB 3.0 USB Type-C | Ethernet HDMI 1.4/1.3 HDMI 2.0 LVDS SATA/PCIe USB 3.0 USB Type-C | USB Type-C | Audio GPIO General Purpose Push Button | Audio Ethernet General Purpose LVDS USB 2.0 | General Purpose | HDMI 1.4/1.3 HDMI 2.0 USB 3.0 USB Type-C | Ethernet HDMI 1.4/1.3 HDMI 2.0 LVDS SATA/PCIe USB 3.0 USB Type-C |
| 0201 0402 | N/A | 0201 0402 | 0402 | 0201 0402 | 0402 | 0402 | 0201 | N/A | N/A | |
| Bi-Directional | Bi-Directional | Bi-Directional | Uni-Directional | Uni-Directional | Bi-Directional | Bi-Directional | Bi-Directional | Bi-Directional | Bi-Directional | Uni-Directional |
| 10 | 10 | 10 | 10 | 10 | 10 | 100 | 100 | 100 | 10 | 10 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| X1SON X2SON | X2SON X2SON | USON | X1SON X2SON | X1SON | X1SON X2SON | X1SON | X1SON | X2SON | USON | USON |
| 2X1SON: 1 mm2: 1 x .6(X1SON) 2X2SON: 0 mm2: .3 x .6(X2SON) | 3X2SON: 1 mm2: .6 x 1(X2SON) 3X2SON: 1 mm2: .6 x 1.3(X2SON) | 10USON: 3 mm2: 1 x 2.5(USON) | 2X1SON: 1 mm2: 1 x .6(X1SON) 2X2SON: 0 mm2: .3 x .6(X2SON) | 2X1SON: 1 mm2: 1 x .6(X1SON) | 2X1SON: 1 mm2: 1 x .6(X1SON) 2X2SON: 0 mm2: .3 x .6(X2SON) | 2X1SON: 1 mm2: 1 x .6(X1SON) | 2X1SON: 1 mm2: 1 x .6(X1SON) | 2X2SON: 0 mm2: .3 x .6(X2SON) | 10USON: 3 mm2: 1 x 2.5(USON) | 10USON: 3 mm2: 1 x 2.5(USON) |
| 0.57 | 0.5 | 0.5 | 0.25 | 0.8 | 1.0 | 0.8 | 0.15 | 0.55 | 0.47 | 0.8 |
| 7.0 | 5.3 | 10 | 7.2 | 10 | 6.3 | 10 | 6.6 | 10 | ||
| 2X1SON 2X2SON | 3X2SON 3X2SON | 10USON | 2X1SON 2X2SON | 2X1SON | 2X1SON 2X2SON | 2X1SON | 2X1SON | 2X2SON | 10USON | 10USON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
