数据:
ESD204 4 通道低电容浪涌和 ESD 保护二极管 数据表
ESD204是一种双向TVS ESD保护二极管阵列,用于高达5.5A(8 /20μs)的HDMI和USB浪涌保护.ESD204的额定ESD冲击消散值达到了IEC 61000-4-2(4级)国际标准中规定的最高水平。
ESD204提供低钳位和高差分带宽,使器件可干净地传输高速信号,并且为下游器件提供强大的保护。该器件具有每通道有一个0.55pF IO电容,适用于保护速率高达6Gbps的高速接口(例如HDMI 2.0,HDMI 1.4,USB 3.0和以太网1G)。低动态电阻和低钳位电压确保系统级抗瞬变事件保护。
ESD204采用符合行业标准的USON-10(DQA)封装。该封装采用直通布线,其引脚间距为0.5mm,能够简化实现并缩短设计时间。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| IO Capacitance (Typ) (pF) |
| Breakdown Voltage (Min) (V) |
| IEC 61000-4-2 Contact (+/- kV) |
| IEC 61000-4-2 Air-Gap (+/- kV) |
| Interface |
| Features |
| Bi-/Uni-Directional |
| IO Leakage Current (Max) (nA) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Dynamic Resistance (Typ) (Ω) |
| Clamping Voltage (V) |
| Pin/Package |
| ESD204 | ESD122 | ESD224 | TPD1E04U04 | TPD4E02B04 | TPD4E05U06 |
| 4 | 2 | 4 | 1 | 4 | 4 |
| 0.55 | 0.2 | 0.5 | 0.5 | 0.25 | 0.5 |
| 5.5 | 5.1 | 6.2 | 5 | 5.5 | 6.5 |
| 30 | 18 | 12 | 16 | 12 | 12 |
| 30 | 18 | 15 | 16 | 15 | 15 |
| Ethernet HDMI 1.4 HDMI 1.4/1.3 HDMI 2.0 LVDS USB 2.0 USB 3.0 | HDMI 1.4/1.3 HDMI 2.0 SATA/PCIe USB 2.0 USB 3.0 USB Type-C | HDMI 1.4 HDMI 1.4/1.3 HDMI 2.0 USB 2.0 USB 3.0 USB Type-C | HDMI 1.4/1.3 HDMI 2.0 USB 2.0 USB 3.0 USB Type-C | HDMI 1.4/1.3 HDMI 2.0 USB 3.0 USB Type-C | Ethernet HDMI 1.4/1.3 HDMI 2.0 LVDS SATA/PCIe USB 3.0 USB Type-C |
| N/A | 0201 0402 | N/A | N/A | ||
| Bi-Directional | Bi-Directional | Bi-Directional | Uni-Directional | Bi-Directional | Uni-Directional |
| 10 | 10 | 10 | 10 | 10 | |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| USON | X2SON X2SON | USON | X1SON X2SON | USON | USON |
| 10USON: 3 mm2: 1 x 2.5(USON) | 3X2SON: 1 mm2: .6 x 1(X2SON) 3X2SON: 1 mm2: .6 x 1.3(X2SON) | 10USON: 3 mm2: 1 x 2.5(USON) | 2X1SON: 1 mm2: 1 x .6(X1SON) 2X2SON: 0 mm2: .3 x .6(X2SON) | 10USON: 3 mm2: 1 x 2.5(USON) | 10USON: 3 mm2: 1 x 2.5(USON) |
| 0.3 | 0.5 | 0.5 | 0.25 | 0.47 | 0.8 |
| 5.3 | 6.6 | 10 | |||
| 10USON | 3X2SON 3X2SON | 10USON | 2X1SON 2X2SON | 10USON | 10USON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
