SN74GTLP22033 具有独立 LVTTL 端口和反馈路径的 8 位 LVTTL-GTLP 可调节边沿速率寄存收发器
KANA 发表于 2018-10-16 11:16:58
数据: 8-Bit LVTTL-to-GTLP Adj.-Edge-Rate Regstd.Xcvr W/ Split LVTTL Port&Feedbk Path 数据表
The SN74GTLP22033 is a high-drive, 8-bit, three-wire registered transceiver that provides inverted LVTTL-to-GTLP and GTLP-to-LVTTL signal-level translation. The device allows for transparent, latched, and flip-flop modes of data transfer with separate LVTTL input and LVTTL output pins, which provides a feedback path for control and diagnostics monitoring, the same functionality as the SN74FB2033. The device provides a high-speed interface between cards operating at LVTTL logic levels and a backplane operating at GTLP signal levels. High-speed (about three times faster than standard LVTTL or TTL) backplane operation is a direct result of GTLP's reduced output swing (<1 V), reduced input threshold levels, improved differential input, OEC™ circuitry, and TI-OPC™ circuitry. Improved GTLP OEC and TI-OPC circuits minimize bus-settling time and have been designed and tested using several backplane models. The high drive allows incident-wave switching in heavily loaded backplanes with equivalent load impedance down to 11 .
The AO outputs, which are designed to sink up to 12 mA, include equivalent 26- resistors to reduce overshoot and undershoot.
GTLP is the Texas Instruments derivative of the Gunning Transceiver Logic (GTL) JEDEC standard JESD 8-3. The ac specification of the SN74GTLP22033 is given only at the preferred higher noise margin GTLP, but the user has the flexibility of using this device at either GTL (VTT = 1.2 V and VREF = 0.8 V) or GTLP (VTT = 1.5 V and VREF = 1 V) signal levels. For information on using GTLP devices in FB+/BTL applications, refer to TI application reports, Texas Instruments GTLP Frequently Asked Questions, literature number SCEA019, and GTLP in BTL Applications, literature number SCEA017.
Normally, the B port operates at GTLP signal levels. The A-port and control inputs operate at LVTTL logic levels, but are 5-V tolerant and can be directly driven by TTL or 5-V CMOS devices. VREF is the B-port differential input reference voltage.
This device is fully specified for live-insertion applications using Ioff, power-up 3-state, and BIAS VCC. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down. The power-up 3-state circuitry places the outputs in the high-impedance state during power up and power down, which prevents driver conflict. The BIAS VCC circuitry precharges and preconditions the B-port input/output connections, preventing disturbance of active data on the backplane during card insertion or removal, and permits true live-insertion capability.
This GTLP device features TI-OPC circuitry, which actively limits overshoot caused by improperly terminated backplanes, unevenly distributed cards, or empty slots during low-to-high signal transitions. This improves signal integrity, which allows adequate noise margin to be maintained at higher frequencies.
High-drive GTLP backplane interface devices feature adjustable edge-rate control (ERC). Changing the ERC input voltage between low and high adjusts the B-port output rise and fall times.This allows the designer to optimize system data-transfer rate and signal integrity to the backplane load.
When VCC is between 0 and 1.5 V, the device is in the high-impedance state during power up or power down. However, to ensure the high-impedance state above 1.5 V, OEAB\ should be tied to VCC through a pullup resistor and OEAB and OEBA should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sinking/current-sourcing capability of the driver.
特性
  • 德州仪器广播公司的成员?家庭
  • TI-OPC ??电路限制在不均匀加载的背板上振铃
  • OEC ??
  • 分离LVTTL端口为控制和诊断监控提供反馈路径
  • 电路改善信号完整性并减少电磁干扰> AO输出等效26- 串联电阻,无需外部电阻
  • LVTTL接口具有5 V容差
  • 高驱动GTLP漏极开路输出(100 mA)
  • 降低LVTTL输出(-12 mA /12 mA)
  • < li>可变边沿速率控制(ERC)输入为分布式负载中的最佳数据传输速率和信号完整性选择GTLP上升和下降时间
  • I off ,上电3 -State和BIAS V CC 支持实时插入
  • 分布式V CC 和GND引脚最大限度地降低高速开关噪声
  • 闩锁性能超过JESD 78,Class II 100 mA
  • ESD保护超过JESD 22
    • 2000-V人体模型(A114-A)
    • 200-V机型(A115-A)
    • 1000-V充电设备型号(C101)
OEC,TI-OPC和Widebus是德州仪器公司的商标。
参数 与其它产品相比 GTL/TTL/BTL/ECL 收发器/转换器
Technology Family
VCC (Min) (V)
VCC (Max) (V)
Bits (#)
Voltage (Nom) (V)
F @ Nom Voltage (Max) (Mhz)
ICC @ Nom Voltage (Max) (mA)
tpd @ Nom Voltage (Max) (ns)
IOL (Max) (mA)
IOH (Max) (mA)
Schmitt Trigger
Operating Temperature Range (C)
Pin/Package
SN74GTLP22033
GTLP
3.15
3.45
8
3.3
175
40
8.8
100
100
No
-40 to 85
48TSSOP
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
