数据:
ISO7310x 优异电磁兼容性 (EMC) 低功耗单通道数字隔离器 数据表 (Rev. D)
ISO7310x可提供符合UL标准的长达1分钟且高达3000 V RMS 的电流隔离,以及符合VDE标准的4242 V PK 隔离。这些器件具有一个隔离通道,其逻辑输入和输出缓冲器由二氧化硅(SiO 2 )绝缘隔栅分离开来。通过与隔离电源一起使用,ISO7310x可防止数据总线或者其它电路上的噪声电流进入本地接地端并干扰或者损坏敏感电路。这些器件已针对恶劣环境集成了噪声滤波器,在此类环境下,器件的输入引ISO7310x具有晶体管晶体管逻辑电路(TTL)输入阈值,工作电压范围为3V到5.5V。凭借创新的芯片设计和布线技术,ISO7310x的电磁兼容性得到了显着增强,从而可确保提供系统级ESD,EFT和浪涌保护并符合辐射标准。
| Integrated Isolated Power |
| Number of Channels (#) |
| Forward/Reverse Channels |
| Isolation Rating (Vrms) |
| Surge Voltage Rating (Vpk) |
| Data Rate (Max) (Mbps) |
| Propagation Delay (Typ) (ns) |
| Default Output |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Rating |
| Operating Temperature Range (C) |
| Pin/Package |
| ISO7310C | ISO721 | ISO721M | ISO722 | ISO722M | ISO7310FC |
| No | No | No | No | No | No |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 1/0 | 1/0 | 1/0 | 1/0 | 1/0 | 1/0 |
| 3000 | 2500 | 2500 | 2500 | 2500 | 3000 |
| 6000 | 4000 | 4000 | 4000 | 4000 | 6000 |
| 25 | 100 | 150 | 100 | 150 | 25 |
| 31 | 17 | 17 | 17 | 19 | 31 |
| High | High | High | High | High | Low |
| 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 |
| 5 | 5 | 5 | 5 | 5 | 5 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| 8SOIC | 8SOIC | 8SOIC | 8SOIC | 8SOIC | 8SOIC |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
