数据:
DP83848C/I/VYB/YB PHYTER™ QFP Single Port 10/100 Mb/s Ethernet Physical Layer Transceiver 数据表
需要以太网连接的应用程序数量持续增加,使以太网设备进入更恶劣的环境。
DP83848C /I /VYB /YB旨在通过超出典型工业温度范围的扩展温度性能来应对这些新应用的挑战。 DP83848C /I /VYB /YB是一款高度可靠,功能丰富,功能强大的器件,符合IEEE 802.3标准,适用于从商业到极端温度的多种温度范围。该器件非常适用于无线远程基站,汽车/运输和工业控制应用等恶劣环境。
它提供增强的ESD保护,并可选择MII或RMII接口,以实现MPU的最大灵活性选择;全部采用48引脚封装。
DP83848VYB扩展了PHYTER™系列器件的领先地位,具有较宽的工作温度范围。 TI系列PHYTER收发器基于数十年的以太网专业知识,可提供高性能和灵活性,使最终用户能够轻松实现定制,以满足这些应用需求。
| Function |
| Port Count |
| Datarate (Mbps) |
| Interface |
| Supply Voltage (Volt) |
| Cable Length (m) |
| JTAG1149.1 |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| DP83848VYB | DP83848C | DP83848H | DP83848I | DP83848J | DP83848K | DP83848Q-Q1 | DP83848YB | DP83867IR |
| PHY | PHY | PHY | PHY | PHY | PHY | PHY | PHY | PHY |
| Single | Single | Single | Single | Single | Single | Single | Single | Single |
| 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100/1000 |
| MII RMII SNI | MII RMII SNI | MII RMII | MII RMII SNI | MII RMII | MII RMII | MII RMII | MII RMII SNI | GMII RGMII MII |
| 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 1.1 2.5 |
| 150 | 137 | 137 | 150 | 137 | 137 | 150 | 150 | 130 |
| Yes | No | No | Yes | No | No | No | Yes | Yes |
| AEC-Q100 Grade 2 | Cable Diagnostics IEEE 1588 SOF | |||||||
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Automotive | Catalog | Catalog |
| -40 to 105 | 0 to 70 | -40 to 125 | -40 to 85 | 0 to 70 | -40 to 85 | -40 to 105 | -40 to 125 | -40 to 85 |
| HLQFP | LQFP | WQFN | LQFP | WQFN | WQFN | WQFN | HLQFP | HTQFP VQFN |
| 48HLQFP: 81 mm2: 9 x 9(HLQFP) | 48LQFP: 81 mm2: 9 x 9(LQFP) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 48LQFP: 81 mm2: 9 x 9(LQFP) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 48HLQFP: 81 mm2: 9 x 9(HLQFP) | 64HTQFP: 144 mm2: 12 x 12(HTQFP) 48VQFN: 49 mm2: 7 x 7(VQFN) |
| 48HLQFP | 48LQFP | 40WQFN | 48LQFP | 40WQFN | 40WQFN | 40WQFN | 48HLQFP | 48VQFN 64HTQFP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
