数据:
DP83848x PHYTER Mini / LS Single Port 10/100 MB/s Ethernet
Transceiver 数据表
DP83848x器件可满足嵌入式系统中空间敏感应用所需的质量,可靠性和小外形尺寸。
DP83848x提供高性能远远超过IEEE规范,具有卓越的互操作性和业界领先的性能,超过137米的Cat-V电缆。 DP83848x还提供Auto-MDIX,以消除布线复杂性。 DP83848x具有出色的ESD保护,超过4 kV人体模型,提供极高的可靠性和稳健的操作,确保在所有应用中实现高水平性能。
DP83848J /K提供两个灵活的LED指示灯,一个用于Link另一个是速度。此外,支持MII和RMII,确保设计的简便性和灵活性。
DP83848H /M /T采用25 MHz时钟输出,无需额外的空间和成本时钟源组件。
DP83848x采用小型6 mm×6 mm WQFN 40引脚封装,是工业控制,建筑/工厂自动化,运输,测试设备和无线基座的理想选择站。
所有商标均为其所有商标主人。
| Function |
| Port Count |
| Datarate (Mbps) |
| Interface |
| Supply Voltage (Volt) |
| Cable Length (m) |
| JTAG1149.1 |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| DP83848H | DP83848C | DP83848I | DP83848J | DP83848K | DP83848Q-Q1 | DP83848VYB | DP83848YB | DP83867IR |
| PHY | PHY | PHY | PHY | PHY | PHY | PHY | PHY | PHY |
| Single | Single | Single | Single | Single | Single | Single | Single | Single |
| 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100 | 10/100/1000 |
| MII RMII | MII RMII SNI | MII RMII SNI | MII RMII | MII RMII | MII RMII | MII RMII SNI | MII RMII SNI | GMII RGMII MII |
| 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 1.1 2.5 |
| 137 | 137 | 150 | 137 | 137 | 150 | 150 | 150 | 130 |
| No | No | Yes | No | No | No | Yes | Yes | Yes |
| AEC-Q100 Grade 2 | Cable Diagnostics IEEE 1588 SOF | |||||||
| Catalog | Catalog | Catalog | Catalog | Catalog | Automotive | Catalog | Catalog | Catalog |
| -40 to 125 | 0 to 70 | -40 to 85 | 0 to 70 | -40 to 85 | -40 to 105 | -40 to 105 | -40 to 125 | -40 to 85 |
| WQFN | LQFP | LQFP | WQFN | WQFN | WQFN | HLQFP | HLQFP | HTQFP VQFN |
| 40WQFN: 36 mm2: 6 x 6(WQFN) | 48LQFP: 81 mm2: 9 x 9(LQFP) | 48LQFP: 81 mm2: 9 x 9(LQFP) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 40WQFN: 36 mm2: 6 x 6(WQFN) | 48HLQFP: 81 mm2: 9 x 9(HLQFP) | 48HLQFP: 81 mm2: 9 x 9(HLQFP) | 64HTQFP: 144 mm2: 12 x 12(HTQFP) 48VQFN: 49 mm2: 7 x 7(VQFN) |
| 40WQFN | 48LQFP | 48LQFP | 40WQFN | 40WQFN | 40WQFN | 48HLQFP | 48HLQFP | 48VQFN 64HTQFP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
