数据:
DS90URxxx-Q1 5-MHz to 43-MHz DC-Balanced 24-Bit FPD-Link II Serializer and Deserializer Chipset 数据表
DS90URxxx-Q1芯片组将24位并行总线转换为带有嵌入式时钟信息的完全透明数据/控制FPD-Link II LVDS串行流。该芯片组非常适合将图形数据驱动到需要18位色深的显示器:RGB666 + HS,VS,DE +三个额外的通用数据通道。这种单串行流通过消除并行数据和时钟路径之间的偏差问题,简化了在PCB走线和电缆上传输24位总线的过程。该器件通过缩小数据路径来节省系统成本,从而减少PCB层,电缆宽度,连接器尺寸和引脚。
DS90URxxx-Q1在高速I /上集成了FPD-Link II LVDS信号O. FPD-Link II LVDS提供低功耗和低噪声环境,可通过串行传输路径可靠地传输数据。通过针对工作频率范围优化串行器输出边沿速率,EMI进一步降低。
此外,该器件具有预加重功能,可使用有损电缆在较长距离上增强信号。内部DC平衡编码和解码用于支持AC耦合互连。使用TI的专有随机锁定,串行器的并行数据随机化到解串器,无需REFCLK。
| Function |
| Color Depth (bpp) |
| Pixel Clock Min (MHz) |
| Pixel Clock (Max) (MHz) |
| Input Compatibility |
| Output Compatibility |
| Signal Conditioning |
| EMI Reduction |
| Diagnostics |
| Total Throughput (Mbps) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| DS90UR241-Q1 | DS90C124 | DS90C124-Q1 | DS90C241 | DS90C241-Q1 | DS90UR124 | DS90UR124-Q1 | DS90UR241 | DS99R101 | DS99R103 | DS99R105 |
| Serializer | Deserializer | Deserializer | Serializer | Serializer | Deserializer | Deserializer | Serializer | Serializer | Serializer | Serializer |
| 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
| 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 3 | 3 | 3 |
| 43 | 35 | 35 | 35 | 35 | 43 | 43 | 43 | 40 | 40 | 40 |
| LVCMOS | FPD-Link II LVDS | FPD-Link II LVDS | LVCMOS | LVCMOS | FPD-Link II LVDS | FPD-Link II LVDS | LVCMOS | LVCMOS | LVCMOS | LVCMOS |
| FPD-Link LVDS | LVCMOS | LVCMOS | FPD-Link LVDS | FPD-Link LVDS | LVCMOS | LVCMOS | FPD-Link LVDS | FPD-Link LVDS | FPD-Link LVDS | FPD-Link LVDS |
| Pre-Emphasis VOD Select | Pre-Emphasis VOD Select | Pre-Emphasis VOD Select | Pre-Emphasis VOD Select | Pre-Emphasis | Fixed Pre-Emphasis | |||||
| Progressive Turn On (PTO) Slew Rate Control | Progressive Turn On (PTO) Slew Rate Control | Adjustable Progressive Turn On (PTO) Slew Rate Control | Adjustable Progressive Turn On (PTO) Slew Rate Control | Progressive Turn On (PTO) | ||||||
| BIST | BIST | BIST | BIST | BIST | BIST | |||||
| 1032 | 840 | 840 | 840 | 840 | 1032 | 1032 | 1032 | 960 | 960 | 960 |
| Automotive | Catalog | Automotive | Catalog | Automotive | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog |
| -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | -40 to 105 | 0 to 70 | -40 to 85 | 0 to 70 |
| TQFP | TQFP | TQFP | TQFP | TQFP | TQFP | TQFP | TQFP | TQFP | TQFP WQFN | TQFP WQFN |
| 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 64TQFP: 144 mm2: 12 x 12(TQFP) | 64TQFP: 144 mm2: 12 x 12(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) | 48TQFP: 81 mm2: 9 x 9(TQFP) 48WQFN: 49 mm2: 7 x 7(WQFN) | 48TQFP: 81 mm2: 9 x 9(TQFP) 48WQFN: 49 mm2: 7 x 7(WQFN) |
| 48TQFP | 48TQFP | 48TQFP | 48TQFP | 48TQFP | 64TQFP | 64TQFP | 48TQFP | 48TQFP | 48TQFP 48WQFN | 48TQFP 48WQFN |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
