数据:
2.5-V/3.3-V Oscillator Gain Stage/Buffers 数据表
这四个器件是高频振荡器增益级,支持3.3V或2.5V系统中高增益输出的LVPECL或LVDS。此外,还提供单端输入(SN65LVx16上的PECL电平)和SN65LVx17上的全差分输入选项。
SN65LVx16为用户提供了增益控制(GC),用于控制 Q 输出从300 mV到860 mV,方法是将其打开(NC),接地或连接到V CC 。 (当打开时, Q 输出默认为575 mV。) Q SN65LVx17默认也为575 mV。
两款器件均提供电压基准电压(V BB ),通常低于V CC 1.35 V,用于接收单端PECL输入信号。不使用时,V BB 应该是未连接或打开的。
所有器件的特点是在-40°C至85°C的温度范围内工作。
| Device Type |
| Protocols |
| No. of Tx |
| No. of Rx |
| Input Signal |
| Output Signal |
| Signaling Rate (Mbps) |
| ESD HBM (kV) |
| Function |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| SN65LVP16 | SN65CML100 | SN65LVDS100 | SN65LVDS101 | SN65LVDS17 | SN65LVDS18 | SN65LVDS19 | SN65LVDS20 | SN65LVP17 | SN65LVP18 | SN65LVP19 | SN65LVP20 |
| Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer |
| PECL | CML | LVDS | LVDS | PECL | PECL | PECL | PECL | PECL | PECL | PECL | PECL |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Single-Ended | CML LVDS LVPECL | CML LVDS LVPECL | CML LVDS LVPECL | Differential | Single-Ended | Differential | Differential | Differential | Single-Ended | Differential | Differential |
| LVPECL | CML | LVDS | LVPECL | LVDS | LVDS | LVDS | LVDS | LVPECL | LVPECL | LVPECL | LVPECL |
| 4000 | 1500 | 2000 | 2000 | 4000 | 2000 | 2000 | 4000 | 4000 | 4000 | 2000 | 4000 |
| 3 | 5 | 5 | 5 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| Buffer | Repeater/Translator | Repeater/Translator | Repeater/Translator | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Buffer | Repeater/Translator |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| WSON | SOIC VSSOP | SOIC VSSOP | SOIC VSSOP | WSON | WSON | WSON | WSON | WSON | WSON | WSON | WSON |
| See datasheet (WSON) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) | See datasheet (WSON) |
| 8WSON | 8SOIC 8VSSOP | 8SOIC 8VSSOP | 8SOIC 8VSSOP | 8WSON | 8WSON | 8WSON | 8WSON | 8WSON | 8WSON | 8WSON | 8WSON |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
