[原创] Avnet PicoZed SOM模块化系统开发方案
应用案例
3人已加入
Avnet公司的PicoZed模块化系统(SOM)是基于Xilinx Zynq-7000全编程(AP) SoC设计的超级灵活可靠的模块化系统(SOM),为设计者提供引脚兼容的在7010,7015,7020和7030 Zynq-7000全编程(AP) SoC器件间灵活移植.PicoZed模块内含存储器,配置,以太网,USB 以及时钟等支持大多数SoC设计核心所需的常见功能.主要用在嵌入模块化系统,嵌入可视系统,马达控制,测试测量,软件定义无线电(SDR)以及工业自动化.本文介绍了开发板PicoZed SOM主要特性,框图,电路图,材料清单和PCB设计图.
The PicoZed SOM is designed to operate while plugged into a Carrier Card or base module, not as a standalone module. Some documentation, such as Board Definition files, Board Support Packages, and Application examples only apply to a PicoZed / Carrier Card combination so this type of documentation will be posted under the PicoZed Carrier Card pages.
PicoZed™ is a highly flexible, rugged, System-On-Module, or SOMthat is based on the Xilinx Zynq?-7000 All Programmable SoC. Itoffers designers the flexibility to migrate between the 7010, 7015,7020, and 7030 Zynq-7000 All Programmable SoC devices in a pin-compatible footprint.
The PicoZed module contains the common functions required to support thecore of most SoC designs, including memory, configuration, Ethernet, USB,and clocks. It provides easy access to over 100 user I/O pins through three I/Oconnectors on the backside of the module. These connectors also supportaccess to dedicated interfaces for Ethernet, USB, JTAG, power and othercontrol signals, as well as the GTP/GTX transceivers on the 7015/7030 models.
The transceiver based 7015 and 7030 versions of PicoZed are a superset ofthe 7010/7020 version, adding four high-speed serial transceiver ports to theI/O connectors. Designers can simply design their own carrier card, plug-inPicoZed, and start their application development with a proven Zynq-7000 AllProgrammable SoC sub-system.
PicoZed SOM主要特性:
User I/O (via three board-to-board connectors)
--7Z010 Version
--113 User I/O (100 PL, 13 PS MIO)
--PL I/O configurable as up to 48 LVDS pairs or 100 single-ended I/O
--7Z015 Version
--148 User I/O (135 PL, 13 PS MIO)
--PL I/O configurable as up to 65 LVDS pairs or 135 single-ended I/O
--4 GTP transceivers
--7Z020 Version
--138 User I/O (125 PL, 13 PS MIO)
--PL I/O configurable as up to 60 LVDS pairs or 125 single-ended I/O
--7Z030 Version
--4 GTX transceivers
PicoZed SOM其它特性:
--SoC options
--XC7Z010-1CLG400
--XC7Z020-1CLG400
--XC7Z015-1SBG485
--XC7Z030-1SBG485
--Memory
--1 GB of DDR3 SDRAM
--128 Mb of QSPI Flash
--4 GB eMMC
--Communications
--10/100/1000 Ethernet PHY
--USB 2.0 PHY
--Other
--JTAG configuration port accessible
via I/O connectors
--PS JTAG pins accessible via I/O connectors
--33.33 MHz oscillator
--Software
--Linux BSP and reference design
PicoZed SOM目标应用:
--Embedded system-on-module (SOM)
--Embedded vision
--Test & measurement
--Motor control
--Software-defined radio
--Industrial automation
图1.开发板PicoZed SOM外形图
图2.开发板PicoZed SOM框图
图3.开发板PicoZed SOM电路图(1)
图4.开发板PicoZed SOM电路图(2)
图5.开发板PicoZed SOM电路图(3)
图6.开发板PicoZed SOM电路图(4)
图7.开发板PicoZed SOM电路图(5)
图8.开发板PicoZed SOM电路图(6)
图9.开发板PicoZed SOM电路图(7)
图10.开发板PicoZed SOM电路图(8)
图11.开发板PicoZed SOM电路图(9)
图12.开发板PicoZed SOM电路图(10)
图13.开发板PicoZed SOM电路图(11)
图14.开发板PicoZed SOM电路图(12)
开发板PicoZed SOM材料清单:
图15.开发板PicoZed SOM PCB设计图(1)
图16.开发板PicoZed SOM PCB设计图(2)
图17.开发板PicoZed SOM PCB设计图(3)
详情请见:
以及%2CE-01-01%2CSchematic%20Prints.PDF
和%2CE-01-01%2CAssembly%20Drawings.PDF
5048-PB-PDP-AES-Z7PZ-SOM-G-V2.pdf
5282-UG-PicoZed-7010_7020-v2_0.pdf
PRJ-PZ1SOM,E-01-01,Schematic Prints.PDF
PRJ-PZ1SOM,E-01-01,Assembly Drawings.PDF
  • 相关推荐
  • 热点推荐
