在电子工程师的日常工作中,视频信号传输的设计是一个常见且关键的任务。今天我们就来深入探讨RENESAS的EL4543,一款专为视频信号传输设计的高性能芯片。
文件下载:EL4543IUZ.pdf
EL4543是一款高带宽的三通道差分放大器,它集成了视频同步信号编码功能。其输入既可以处理单端形式的高速视频或其他通信信号,也能处理差分形式的信号。而且,它的共模输入范围能够延伸至负电源轨,这使得在单电源应用中可以实现接地参考信号传输。高带宽特性让它能够以极低的谐波失真将差分信号传输到标准双绞线或同轴电缆上,内部反馈机制则确保了输出端的增益和相位平衡,有效降低了辐射电磁干扰(EMI)和谐波。
提供无铅版本(符合RoHS标准),符合环保要求。
| EL4543通过嵌入式逻辑将标准视频的水平和垂直同步信号编码到双绞线的共模上,在不需要额外缓冲器或传输线的情况下传输这些额外信息,相比分立线路驱动器方案,能显著节省系统成本。具体的同步信号编码规则如下表所示: | H | V | COMMON MODE A (RED) | COMMON MODE B (GREEN) | COMMON MODE C (BLUE) |
| Low | High | 3.0 | 2.0 | 2.5 | |
| Low | Low | 2.5 | 3.0 | 2.0 | |
| High | Low | 2.0 | 3.0 | 2.5 | |
| High | High | 2.5 | 2.0 | 3.0 |
| PARAMETER | DESCRIPTION | CONDITIONS | MIN (Note 1) | TYP | MAX (Note 1) | UNIT |
| AC PERFORMANCE | ||||||
| BW (-3dB) | -3dB Bandwidth | V OUT = 2V P-P | 350 | MHz | ||
| SR | Differential Slew Rate | R L = 200 | 600 | 1000 | V/µs | |
| T STL | Settling Time to 0.1% | 13.6 | ns | |||
| GBW | Gain Bandwidth Product | 700 | MHz | |||
| HD2 | 2nd Harmonic Distortion | f = 20MHz, R L = 200 | -70 | dBc | ||
| HD3 | 3rd Harmonic Distortion | f = 20MHz, R L = 200 | -70 | dBc | ||
| dP | Differential Phase @ 3.58MHz | 0.01 | ° | |||
| dG | Differential Gain @ 3.58MHz | 0.01 | % | |||
| INPUT CHARACTERISTICS | ||||||
| V OS | Input Referred Offset Voltage | -10 | 2 | 10 | mV | |
| I IN | Input Bias Current (V IN +, V IN +) | -30 | -15 | -10 | µA | |
| Z IN | Differential Input Impedance | 180 | k | |||
| C IN | Input Capacitance | Capacitance between any single input pin and the power supplies | 4 | pF | ||
| V DIFF | Differential Input Range | ±0.75 | V | |||
| V CM | Input Common Mode Voltage Range | V S + = +5V, V S - = 0V. See Figure 7 for higher supply voltages. | 0 | 2.3 | V | |
| V N | Input Referred Voltage Noise | 27 | nV/ Hz | |||
| CMRR | Input Common Mode Rejection Ratio | V CM = 0 to 2V | 60 | 80 | dB | |
| EN | Threshold | 1.4 | V | |||
| OUTPUT CHARACTERISTICS | ||||||
| I OUT | Output Peak Current | 40 | 60 | mA | ||
| C OUT | Output Capacitance (Disabled) | Capacitance between any single output pin and the power supplies when disabled | 12 | pF | ||
| DC PERFORMANCE | ||||||
| A V | Voltage Gain | V IN = 0.8V P-P | 1.82 | 1.96 | 2.05 | V/V |
| SUPPLY CHARACTERISTICS | ||||||
| V SUPPLY | Supply Operating Range | V S + to V S - | 5 | 12 | V | |
| I S | Power Supply Current (per Channel) | 12.3 | 14.5 | 16.2 | mA | |
| PSRR | Power Supply Rejection Ratio | 70 | 80 | dB |
文档中给出了一系列典型性能曲线,包括共模输出、不同负载和电容下的差分频率响应、平衡误差、共模抑制比(CMRR)、电源抑制比(PSRR)等。这些曲线能够帮助工程师更好地了解芯片在不同条件下的性能表现,从而进行合理的设计和优化。例如,通过频率响应曲线可以确定芯片在不同频率下的增益变化,以便选择合适的工作频率范围。
EL4543提供三个全差分高速放大器,适用于将高分辨率复合视频信号驱动到双绞线或标准同轴电缆上。其输入共模范围延伸至负电源轨,允许在单电源下使用简单的接地参考输入终端。放大器提供固定增益 +2,以补偿标准视频电缆终端方案。水平和垂直同步信号(HSYNC和VSYNC)被传递到内部逻辑编码块,将同步信息编码为三个不同电压水平的离散信号。最终输出由三个全差分视频信号组成,同步信息编码在三个RGB差分信号的共模上。
EL4543将HSYNC和VSYNC信号编码在差分视频信号的共模输出上,分别对应红、绿、蓝通道。这种编码方式使得共模电压之和形成一个固定的平均直流电平,没有交流成分,从而消除了CAT5电缆双绞线中任何共模信号的电磁干扰辐射。
可以从共模同步输出电压中再生HSYNC和VSYNC。HSYNC、VSYNC和三个共模电平之间的关系由前面提到的同步信号编码表给出。通过在每个差分通道的电缆接收器输入处使用简单的电阻网络,可以轻松地从EL4543的差分输出中分离出共模电平。
文档给出了一个50Ω串联终端和100Ω双绞线电缆的终端方案。需要注意的是,共模终端电阻RCM应大于100Ω,以避免对EL4543造成过大负载。
EL4543适用于通过长达100英尺的电缆传输视频信号。但随着传输线长度的增加,信号损失会增大,此时需要额外的支持来均衡视频信号。文档中提到的SXGA视频传输系统可以实现长达1000英尺的RGB视频加同步信号的传输,其中EL9110用于信号均衡和共模提取。
EL4543具有内部短路保护,典型设置为60mA。如果输出长时间短路,增加的功耗最终会损坏芯片。为了实现最大可靠性,输出电流不应超过60mA,50Ω串联背载匹配电阻提供了额外的保护。
EL4543可以在±5V分离电源或单0V至5V电源下工作。需要注意的是,输入逻辑阈值相对于负电源引脚,因此在使用分离电源时,单电源接地参考逻辑将无法正常工作。当使用±5V分离电源时,需要对输入同步信号进行电压偏移。
EL4543提供使能/禁用功能,逻辑输入高电平时在900ns内关闭电源,逻辑输入低电平时在212ns内开启电源。禁用时,放大器的电源电流降至1.8mA(正电源)和0mA(负电源)。使能/禁用阈值是电源电压水平的线性函数,与标准TTL/CMOS兼容,并参考最低电源电位。
PCB布局时,建立一个“健康”的接地平面至关重要。要尽可能缩短所有走线,将电源旁路组件尽可能靠近芯片,创建低阻抗且连续的接地路径,在多层板的高频应用中尽量保持一层具有连续的接地平面和最小的过孔切口,提供从电源引脚到接地的极短回路。如果条件允许,使用铁氧体磁珠可以隔离设备与电源噪声以及电路其他部分的噪声。
在高速切换或驱动重负载时,EL4543的驱动能力最终受限于内部功耗导致的管芯温度上升。为了可靠运行,管芯温度必须保持在 (T{JMAX})(125°C)以下。在选择封装类型之前,需要计算给定应用的功耗,计算公式为: [P D=3 timesleft(V{S} × I{S M A X}+V{S} × frac{Delta V{O}}{R{L D}}right)] 其中,(V{S}) 是EL4543的总电源(从 (V{S^{+}}) 到 (V{S}) -),(I{SMAX}) 是每通道的最大静态电源电流,(Delta V{O}) 是应用的最大差分输出电压,(R{L D}) 是差分负载电阻。 获得应用的功耗后,可以计算最大结温: [T{J M A X}=T{M A X}+Theta{J A} × P D] 其中,(T{JMAX}) 是最大结温(125°C),(TMAX) 是最大环境工作温度,(PD) 是上述计算的功耗,(theta_{JA}) 是应用(封装 + PCB组合)的热阻,可参考封装功耗曲线。
VGA输入的RGB加同步信号通过75Ω终端连接到EL4543的输入。单端RGB视频被转换为差分模式信号,HSYNC和VSYNC分别编码在三个差分信号的共模上。50Ω输出终端的EL4543将编码有同步共模的差分RGB信号驱动到CAT5双绞线电缆上。在没有信号频率均衡的情况下,该系统可以在长达200英尺的CAT5双绞线上满意地传输信号。对于更长的电缆长度,建议使用EL9110进行频率和增益均衡以补偿信号衰减,并使用EL9115的延迟线技术调整接收端信号之间的相位失配。
这是一个低成本的交钥匙系统,用于在短至中等长度(1至500英尺)的CAT5电缆上传输分量视频,并具有可选的电缆损耗和偏斜补偿功能。RGB视频加同步信号(5通道)在VGA终端接收并以单端形式输入到EL4543。EL4543将单端RGB转换为三个双绞线上的全差分信号,同步信号编码在三个RGB差分信号的差分共模上,然后通过CAT5电缆驱动这些编码同步的差分信号。信号的共模通过无源电阻网络从差分信号中提取,并传递到EL8201进行同步解码。差分信号直接传递到EL5375进行放大并转换回单端格式。该系统利用单个通道的2极补偿来应对150、300和500英尺的电缆长度,并可以通过补偿网络对CAT5线对之间的电缆长度差异进行一定程度的电缆传播延迟偏斜补偿。
RENESAS的EL4543是一款功能强大、性能卓越的视频驱动芯片,它在视频信号传输方面具有诸多优势。通过合理的设计和应用,可以实现高效、稳定的视频信号传输。在实际设计中,工程师需要根据具体的应用需求,结合芯片的特性和参数,进行全面的考虑和优化。同时,正确的布局技术和功耗计算也是确保系统可靠性和稳定性的关键因素。大家在使用EL4543进行设计时,是否也遇到过一些挑战呢?欢迎在评论区分享你的经验和想法。
