51单片机开机复位、按键复位原理讲解
今日头条
1193人已加入
51单片机开机复位、按键复位原理讲解
5   视频讲解
1  复位要求Reset输入的高电平持续时间大于等于0.2uS。
2  开机复位:开机启动的瞬间,电解电容导通,所以Reset的电平为5V,电解电容进入充电阶段,由于电解电容为10uF,电阻为10K,所以电解电容的充电时间为0.1S。Reset的电压从5V开始降低,由于单片机识别1.5V以上为高电平,所以在电解电容充电过程中,Reset由5V降到1.5V期间为高电平,1.5V降到0V为低电平,电解电容充满点后,Reset维持在低电平,系统开机复位完成,进入运行阶段。
3  按键复位:按键按下之前,电解电容是在开机复位后的状态,也就是电容充满电,Reset为0V,按键按下后,电解电容和按键组成回路,电解电容开始放电,Reset电压升高0V到5V,当升高到1.5V时,Reset变为高电平,升高到5V,电解电容完全放电完成,由于按键已经放开,所以电解电容开始充电,此后的过程和开机启动相同,所以按键复位的高电平维持时间比开机复位长。
4  复位电路
评论(0)
发评论
gztoppower 2022-08-23
0 回复 举报
http://house.china.com.cn/sousou/%25CB%25D1%25BA%25FC%252C%2B%25B2%25FD%25CA%25A2%25B9%25FA%25BC%25CA%25D5%25E6%25C8%25CB%25D3%25E9%25C0%25D6B2024.cN_1s.htm http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%25D3%25E9%25C0%25D6%252C%2B%25BB%25B7%25C7%25F2%25D3%25E9%25C0%25D6%25D5%25E6%25C8%25CB%25D3%25E9%25C0%25D6B2024.cN%252C%25C0%25F6%25BD%25AD%25C8%25CB%25B2%25C5_3s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%252C%2B%25B2%25FD%25CA%25A2%25D5%25E6%25C8%25CB%25D3%25E9%25C0%25D6B2024.cN%252C%25D6%25EA%25D6%25DE%25B7%25D6%25B9%25AB%25CB%25BE_4s.htm http://house.china.com.cn/sousou/VIP%252C%2B%25C3%25E5%25B5%25E9%25D3%25F1%25CF%25E9%25B9%25AB%25CB%25BEB2024.cN%252C%25C9%25CF%25C8%25C4%25D1%25A7%25B8%25AE_2s.htm http://house.china.com.cn/sousou/%25D3%25E9%25C0%25D6%252C%2B%25C3%25E5%25B5%25E9%25CC%25DA%25C1%25FA%25B6%25B7%25C5%25A3B2024.cN%252C%25B0%25D7%25C9%25BD%25B7%25D6%25B9%25AB%25CB%25BE_38s.htm 收起回复
