汽车电子电磁兼容EMC标准清单
United Nations 联合国
Document Number 文件编号/Title 标题
UNECE R10 联合国欧洲经济委员会R10法规
Uniform provisions concerning the approval of vehicles with regard to electromagnetic compatibility关于车辆电磁兼容性批准的统一规定
CISPR (Automotive Emissions Requirements)国际无线电干扰特别委员会(汽车排放要求)
CISPR 12
Vehicles, boats, and internal combustion engine driven devices - Radio disturbance characteristics - Limits and methods of measurement for the protection of receivers except those installed in the vehicle/boat/device itself or in adjacent vehicles/boats/devices车辆、船舶和内燃机驱动装置——无线电骚扰特性——保护除安装在车辆/船舶/装置本身或相邻车辆/船舶/装置上的接收机以外的接收机的限值和测量方法
CISPR 25
Radio disturbance characteristics for the protection of receivers used on board vehicles, boats, and on devices - Limits and methods of measurement车辆、船舶和设备上使用的接收机保护用无线电骚扰特性——限值和测量方法
CISPR 36
Electric and hybrid electric road vehicles - Radio disturbance characteristics - Limits and methods of measurement for the protection of off-board receivers below 30 MHz电动和混合动力道路车辆——无线电骚扰特性——用于保护30 MHz以下车载外接收机的限值和测量方法
ISO (Automotive Immunity Requirements)ISO(汽车抗扰度要求)
ISO 7637-1
Road vehicles -- Electrical disturbances from conduction and coupling -- Part 1: Definitions and general considerations道路车辆——传导和耦合产生的电干扰——第1部分:定义和一般考虑事项
ISO 7637-2
Road vehicles -- Electrical disturbances from conduction and coupling -- Part 2: Electrical transient conduction along supply lines only道路车辆——传导和耦合产生的电干扰——第2部分:仅沿供电线路的电瞬态传导
ISO 7637-3
Road vehicles -- Electrical disturbance by conduction and coupling -- Part 3: Vehicles with nominal 12 V or 24 V supply voltage -- Electrical transient transmission by capacitive and inductive coupling via lines other than supply lines道路车辆——传导和耦合引起的电干扰——第3部分:标称供电电压为12 V或24 V的车辆——通过非供电线路的电容性和电感性耦合进行的电瞬态传输
ISO/TR 10305-1
Road vehicles -- Calibration of electromagnetic field strength measuring devices -- Part 1: Devices for measurement of electromagnetic fields at frequencies > 0 Hz道路车辆——电磁场强度测量设备的校准——第1部分:频率>0Hz电磁场测量设备
ISO/TR 10305-2
Road vehicles -- Calibration of electromagnetic field strength measuring devices -- Part 2: IEEE standard for calibration of electromagnetic field sensors and probes, excluding antennas, from 9 kHz to 40 GHz道路车辆——电磁场强度测量设备的校准——第2部分:9 kHz至40 GHz频段内电磁场传感器和探头(不包括天线)的IEEE校准标准
ISO 10605
Road vehicles -- Test methods for electrical disturbances from electrostatic discharge道路车辆——静电放电产生的电干扰的试验方法
ISO/TS 14907-1
Road transport and traffic telematics -- Electronic fee collection -- Test procedures for user and fixed equipment -- Part 1: Description of test procedures道路运输和交通远程信息处理——电子收费——用户设备和固定设备的测试程序——第1部分:测试程序说明
ISO/TS 14907-2
Road transport and traffic telematics -- Electronic fee collection -- Test procedures for user and fixed equipment -- Part 2: Conformance test for the onboard unit application interface道路运输和交通远程信息处理——电子收费——用户设备和固定设备的测试程序——第2部分:车载单元应用接口的一致性测试
ISO 21498-1
Electrically Propelled Road vehicles -- Electrical specifications and tests for voltage class B systems and components -- Part 1: Voltage sub-classes and characteristics电动道路车辆——B级电压系统及部件的电气规格和试验——第1部分:电压子等级和特性
ISO 21498-2
Electrically Propelled Road vehicles -- Electrical specifications and tests for voltage class B systems and components -- Part 2: Electrical tests for components电动道路车辆——B级电压系统及部件的电气规格和试验——第2部分:部件的电气试验
ISO/TS 21609
Road vehicles -- (EMC) guidelines for installation of aftermarket radio frequency transmitting equipment道路车辆——(电磁兼容性)售后无线电频率发射设备安装指南
ISO 11451-1
Road vehicles -- Vehicle test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 1: General principles and terminology道路车辆——窄带辐射电磁能量产生的电干扰的车辆试验方法——第1部分:一般原则和术语
ISO 11451-2
Road vehicles -- Vehicle test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 2: Off-vehicle radiation sources道路车辆——窄带辐射电磁能产生的电干扰的车辆试验方法——第2部分:车外辐射源
ISO 11451-3
Road vehicles -- Electrical disturbances by narrowband radiated electromagnetic energy -- Vehicle test methods -- Part 3: On-board transmitter simulation道路车辆——窄带辐射电磁能量产生的电干扰——车辆试验方法——第3部分:车载发射机模拟
ISO 11451-4
Road vehicles -- Vehicle test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 4: Bulk current injection (BCI)道路车辆——窄带辐射电磁能量产生的电干扰的车辆试验方法——第4部分:大电流注入(BCI)
ISO 11452-1
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 1: General principles and terminology道路车辆——窄带辐射电磁能量产生的电干扰的部件试验方法 第1部分:一般原则和术语
ISO 11452-2
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 2: Absorber-lined shielded enclosure道路车辆——窄带辐射电磁能产生的电干扰的部件试验方法——第2部分:吸波材料衬里屏蔽室
ISO 11452-3
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 3: Transverse electromagnetic mode (TEM) cell道路车辆——窄带辐射电磁能产生的电干扰的部件试验方法——第3部分:横向电磁模式(TEM)小室
ISO 11452-4
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 4: Bulk current injection (BCI)道路车辆——窄带辐射电磁能产生的电干扰的部件试验方法——第4部分:大电流注入(BCI)
ISO 11452-5
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 5: Stripline道路车辆——窄带辐射电磁能量产生的电干扰的部件试验方法——第5部分:带状线
ISO 11452-7
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 7: Direct radio frequency (RF) power injection道路车辆——窄带辐射电磁能量产生的电干扰的部件试验方法——第7部分:直接射频(RF)功率注入
ISO 11452-8
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 8: Immunity to magnetic fields道路车辆——窄带辐射电磁能量产生的电干扰的部件试验方法 第8部分:对磁场的抗扰度
ISO 11452-10
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 10: Immunity to conducted disturbances in the extended audio frequency range道路车辆——窄带辐射电磁能量产生的电干扰的部件试验方法——第10部分:对扩展音频频率范围内传导干扰的抗扰度
ISO 11452-11
Road vehicles -- Component test methods for electrical disturbances from narrowband radiated electromagnetic energy -- Part 11: Reverberation chamber道路车辆——窄带辐射电磁能产生的电干扰的部件试验方法 第11部分:混响室
ISO 13766-1
Earth-moving and building construction machinery -- Electromagnetic compatibility (EMC) of machines with internal electrical power supply -- Part 1: General EMC requirements under typical electromagnetic environmental conditions土方和建筑施工机械——自带电源设备的电磁兼容性(EMC)——第1部分:典型电磁环境条件下的一般电磁兼容性要求
ISO 13766-2
  Earth-moving and building construction machinery -- Electromagnetic compatibility (EMC) of machines with internal electrical power supply -- Part 2: Additional EMC requirements for functional safety土方和建筑施工机械——自带电源设备的电磁兼容性(EMC)——第2部分:功能安全的附加电磁兼容性要求
SAE (Automotive Emissions and Immunity)SAE(汽车排放与抗扰性)
J1113/1
Electromagnetic Compatibility Measurement Procedures and Limits for Components of Vehicles, Boats (Up to 15 M), and Machines (Except Aircraft) (50 Hz to 18 Ghz)车辆、船舶(船长不超过15米)和机械(航空器除外)部件的电磁兼容性测量程序和限值(50赫兹至18吉赫兹)
J1113/4
Immunity to Radiated Electromagnetic Fields-Bulk Current Injection (BCI) Method辐射电磁场抗扰度——大电流注入(BCI)法
J1113/11
Immunity to Conducted Transients on Power Leads电源线传导瞬变抗扰度
J1113/12
Electrical Interference by Conduction and Coupling - Capacitive and Inductive Coupling via Lines Other than Supply Lines传导和耦合引起的电气干扰——通过供电线路以外的线路进行的电容耦合和电感耦合
J1113/13
Electromagnetic Compatibility Measurement Procedure for Vehicle Components - Part 13: Immunity to Electrostatic Discharge车辆零部件电磁兼容性测量规程 - 第13部分:对静电放电的抗扰度
J1113/26
Electromagnetic Compatibility Measurement Procedure for Vehicle Components - Immunity to AC Power Line Electric Fields车辆部件电磁兼容性测量规程 - 对交流电源线电场的抗扰度
J1113/27
Electromagnetic Compatibility Measurements Procedure for Vehicle Components - Part 27: Immunity to Radiated Electromagnetic Fields - Mode Stir Reverberation Method车辆零部件电磁兼容性测量规程 - 第27部分:对辐射电磁场的抗扰度 - 模式搅拌混响法
J1752/1
Electromagnetic Compatibility Measurement Procedures for Integrated Circuits-Integrated Circuit EMC Measurement Procedures-General and Definition集成电路电磁兼容性测量程序——集成电路电磁兼容性测量程序通则与定义
J1752/2
Measurement of Radiated Emissions from Integrated Circuits -- Surface Scan Method (Loop Probe Method) 10 MHz to 3 GHz集成电路辐射发射的测量——表面扫描法(环形探针法)10 MHz至3 GHz
J1752/3
Measurement of Radiated Emissions from Integrated Circuits -- TEM/Wideband TEM (GTEM) Cell Method; TEM Cell (150 kHz to 1 GHz), Wideband TEM Cell (150 kHz to 8 GHz)集成电路辐射发射的测量——TEM/宽带TEM(GTEM)小室法;TEM小室(150 kHz至1 GHz)、宽带TEM小室(150 kHz至8 GHz)
J551/15
Vehicle Electromagnetic Immunity--Electrostatic Discharge (ESD)车辆电磁抗扰度——静电放电(ESD)
J551/16
Electromagnetic Immunity - Off-Vehicle Source (Reverberation Chamber Method) - Part 16 - Immunity to Radiated Electromagnetic Fields电磁抗扰度 - 车外源(混响室法) - 第16部分 - 对辐射电磁场的抗扰度
J551/17
Vehicle Electromagnetic Immunity -- Power Line Magnetic Fields车辆电磁抗扰度——电力线磁场
J1812
Function Performance Status Classification for EMC Immunity TestingEMC抗扰度测试的功能性能状态分类
J2628
Characterization--Conducted Immunity 特性描述——传导抗扰度
J2556
Radiated Emissions (RE) Narrowband Data Analysis--Power Spectral Density (PSD)辐射发射(RE)窄带数据分析——功率谱密度(PSD)
GM 通用汽车
GMW3091
General Specification for Vehicles, Electromagnetic Compatibility (EMC)车辆电磁兼容性(EMC)通用规范
Supersedes GMI 12559 R and GMI 12559 V替代GMI 12559 R和GMI 12559 V
GMW3097
General Specification for Electrical/Electronic Components and Subsystems, Electromagnetic Compatibility电气/电子元器件及子系统电磁兼容性通用规范
Supersedes GMW12559, GMW3100, GMW12002R AND GMW12002V替代GMW12559、GMW3100、GMW12002R和GMW12002V
Ford 福特
FMC1278 快速消费品1278
Electromagnetic Compatibility Specification For Electrical/Electronic Components and Subsystems电气/电子元件及子系统电磁兼容性规范
FMC1279 快速消费品1279
EMC Processes 电磁兼容流程
FMC1280 快速消费品1280
Electromagnetic Compatibility Specification For HV E/E Components and Subsystems高压电子电气部件及子系统电磁兼容性规范
Chrysler 勒
DC-10615
Electrical System Performance Requirements for Electrical and Electronic Components电气和电子元件的电气系统性能要求
DC-11224
EMC Performance Requirements -- ComponentsEMC性能要求——零部件
DC-11225
EMC Supplemental Information and Alternative Component RequirementsEMC补充信息和替代组件要求
DC-11223
EMC Performance Requirements -- VehicleEMC性能要求——车辆
Other Automotive Manufacturers 其他汽车制造商
Audi TL 82466 奥迪TL 82466
Electrostatic Discharge 静电放电
BMW 600 13.0 宝马 600 13.0
Electric- / Electronic components in cars汽车中的电气/电子元件
BMW GS 95002 宝马 GS 95002
Electromagnetic Compatibility (EMC) Requirements and Tests电磁兼容性(EMC)要求和测试
BMW GS 95003-2 宝马 GS 95003-2
Electric- / Electronic assemblies in motor vehicles汽车中的电气/电子组件
Chrysler PF 9326 克莱斯勒 PF 9326
Electrical electronic modules and motors电气电子模块和电机
FIAT 9.90110 菲亚特 9.90110
Electric and electronic devices for motor vehicles汽车用电气和电子设备
Freightliner 49-00085
EMC requirements EMC要求
Honda 3838Z-S5AA-L000 本田 3838Z-S5AA-L000
Noise Simulation Test 噪声模拟测试
Honda 3982Z-SDA-0030 本田3982Z-SDA-0030
Hyundai/Kia ES 39110-00 现代/起亚ES 39110-00
EMC requirements 电磁兼容要求
Hyundai/Kia ES-95400-10 现代/起亚ES-95400-10
Battery Simulation Tests 电池模拟测试
Hyundai/Kia ES 96100-01 现代/起亚ES 96100-01
IVECO 16-2103 依维柯 16-2103
EMC requirements 电磁兼容性要求
Jaguar / Land Rover JLR-EMC-CS v1.0捷豹/路虎 JLR-EMC-CS v1.0
Electromagnetic Compatibility Requirements for Electrical/Electronic Components and Subsystems电气/电子元器件及子系统的电磁兼容性要求
Lotus 17.39.01 路特斯 17.39.01
Lotus Engineering Standard: Electromagnetic Compatibility莲花工程标准:电磁兼容性
Mack Trucks 606GS15 马克卡车 606GS15
MAN 3285
Mazda MES PW 67600 马自达MY PW 67600
Automobile parts standard (electronic devices)汽车零部件标准(电子设备)
Mercedes A 211 000 42 99 梅赛德斯 A 211 000 42 99
Instruction specification of test method for E/E-components电子电气部件测试方法说明规范
Mercedes AV EMV 梅赛德斯AV EMV
Electric aggregate and electronics in cars汽车中的电气总成和电子设备
Mercedes MBN 10284-2 梅赛德斯MBN 10284-2
EMC requirements and tests of E/E-systems (component test procedures)电子电气系统的电磁兼容要求与测试(部件测试程序)
Mercedes MBN 22100-2 梅赛德斯MBN 22100-2
Electric / electronic elements, devices in trucks卡车中的电气/电子元件、设备
Mitsubishi ES-X82010 三菱 ES-X82010
General specification of environment tests on automotive electronic equipment汽车电子设备环境试验通用规范
Nissan 28400 NDS03 日产 28400 NDS03
Low frequency surge resistance of electronic parts电子元件的低频浪涌抗性
Nissan 28400 NDS07 日产 28400 NDS07
Immunity against low frequency surge (induction surge) of electronic parts电子部件对低频浪涌(感应浪涌)的抗扰度
Nissan 28401 NDS02 日产 28401 NDS02
EMC requirements (instruction concerning vehicle and electrical ...)电磁兼容性要求(关于车辆和电气……的说明)
Porsche AV EMC EN 保时捷AV EMC EN
PSA B21 7090
EMC requirements (electric and electronics equipment)电磁兼容要求(电气和电子设备)
PSA B21 7110
EMC requirements (electric and electronics equipment)EMC要求(电气和电子设备)
Renault 36.00.400 雷诺 36.00.400
Physical environment of electrical and electronic equipments电气和电子设备的物理环境
Renault 36.00.808 雷诺 36.00.808
EMC requirements (cars and electrical / electronic components)EMC要求(汽车及电气/电子元件)
Scania TB1400 斯堪尼亚TB1400
Scania TB1700 斯堪尼亚 TB1700
Load Dump Test 负载突降测试
Smart DE10005B
EMC requirements (electric aggregate and electronics in cars)EMC要求(汽车中的电气集合体和电子设备)
Toyota TSC7001G 丰田TSC7001G
Engineering standard (electric noise of electronic devices)工程标准(电子设备的电噪声)
Toyota TSC7001G-5.1 丰田TSC7001G-5.1
Power Supply Voltage Characteristic Test电源电压特性测试
Toyota TSC7001G-5.2 丰田TSC7001G-5.2
Field Decay Test 磁场衰减测试
Toyota TSC7001G-5.3 丰田TSC7001G-5.3
Floating Ground Test 悬浮接地测试
Toyota TSC7001G-5.4 丰田TSC7001G-5.4
Induction Noise Resistance 抗感应噪声
Toyota TSC7001G-5.5.3 丰田TSC7001G-5.5.3
Load Dump Test-1 负载突降测试-1
Toyota TSC7001G-5.5.4 丰田TSC7001G-5.5.4
Load Dump Test-2 负载突降测试-2
Toyota TSC7001G-5.5.5 丰田TSC7001G-5.5.5
Load Dump Test-3 负载突降测试-3
Toyota TSC7001G-5.6 丰田TSC7001G-5.6
Over Voltage Test 过电压测试
Toyota TSC7001G-5.7.3 丰田TSC7001G-5.7.3
Ignition Pulse (Battery Waveforms) Test-1点火脉冲(电池波形)测试-1
Toyota TSC7001G-5.7.4 丰田TSC7001G-5.7.4
Ignition Pulse (Battery Waveforms) Test-2点火脉冲(电池波形)测试-2
Toyota TSC7001G-5.8 丰田TSC7001G-5.8
Reverse Voltage 反向电压
Toyota TSC7006G-4.4.2 丰田TSC7006G-4.4.2
Wide Band-Width Antenna Nearby Test (0.4 to 2 GHz)宽带天线近距离测试(0.4至2 GHz)
Toyota TSC7006G-4.4.3 丰田TSC7006G-4.4.3
Radio Equipment Antenna nearby Test (28 MHz ...)无线电设备天线近距离测试(28 MHz...)
Toyota TSC7006G-4.4.4 丰田TSC7006G-4.4.4
Mobile Phone Antenna Nearby Test (835 MHz ...)手机天线近距离测试(835 MHz ...)
Toyota TSC7018G 丰田TSC7018G
Static Electricity Test 静电测试
Toyota TSC7025G-5 丰田TSC7025G-5
TEM Cell Test (1 to 400 MHz) TEM小室测试(1至400兆赫兹)
Toyota TSC7025G-6 丰田TSC7025G-6
Free Field Immunity Test (20 MHz to 1 GHz AM, 0.8 to 2 GHz PM)自由场抗扰度测试(20 MHz至1 GHz调幅,0.8至2 GHz调相)
Toyota TSC7025G-7 丰田TSC7025G-7
Strip Line Test (20 - 400 MHz) 带状线测试(20-400 MHz)
Toyota TSC7026G-3.4 丰田TSC7026G-3.4
Narrow Band Emissions 窄带发射
Toyota TSC7203G 丰田TSC7203G
Voltage Drop / Micro Drops 电压降/微降
Toyota TSC7508G-3.3.1 丰田TSC7508G-3.3.1
Conductive Noise in FM and TV BandsFM和TV频段的传导噪声
Toyota TSC7508G-3.3.2 丰田TSC7508G-3.3.2
Conductive noise in LW, AM and SW Bands长波、调幅和短波波段的传导噪声
Toyota TSC7508G-3.3.3 丰田TSC7508G-3.3.3
Radiated Noise in FM and TV Bands FM和TV频段的辐射噪声
Toyota TSC7508G-3.3.4 丰田TSC7508G-3.3.4
Radiated Noise in AM, SW, and LW Bands调幅、短波和长波频段的辐射噪声
Engineering standard (ABS-TRC computers)工程标准(ABS-TRC计算机)
Toyota TXC7315G 丰田TXC7315G
Electrostatic Discharge (Gap Method) 静电放电(间隙法)
Visteon ES-XU3F-1316-AA 连衣裙ES-XU3F-1316-AA
Electronic Component - Subsystem Electromagnetic Compatibility (EMC) Requirements and Test Procedures电子元件 - 子系统电磁兼容性(EMC)要求和测试程序
Volvo EMC Requirements 沃尔沃电磁兼容性要求
EMC requirements for 12V and 24V systems12V和24V系统的电磁兼容要求
Volkswagen VW TL 801 01 大众汽车 VW TL 801 01
Electric and electronic components in cars汽车中的电气和电子元件
Volkswagen VW TL 820 66 大众汽车 VW TL 820 66
Conducted Interference 传导干扰
Volkswagen VW TL 821 66 大众汽车 VW TL 821 66
EMC requirements of electronic components - bulk current injection (BCI)电子元件的电磁兼容要求 - 大电流注入(BCI)
Volkswagen VW TL 823 66 大众汽车 VW TL 823 66
Coupled Interference on Sensor Cables传感器电缆上的耦合干扰
Volkswagen VW TL 824 66 大众汽车 VW TL 824 66
Immunity Against Electrostatic Discharge抗静电放电干扰能力
Volkswagen VW TL 965 大众汽车 VW TL 965
Short-Distance Interference Suppression近距离干扰抑制
