ESP32/ESP8266开发板单向一对多ESP-NOW无线通信
简介
本实验通过ESP-NOW无线通信协议实现ESP32开发板向多个ESP32/ESP 8266开发板发送数据。
开发板
开发板
读取ESP32/ESP8266接收方Receiver的MAC地址
读取ESP32开发板的代码
#include < WiFi.h >
#include < esp_wifi.h >
void readMacAddress(){
  uint8_t baseMac[6];
  esp_err_t ret = esp_wifi_get_mac(WIFI_IF_STA, baseMac);
  if (ret == ESP_OK) {
    Serial.printf("%02x:%02x:%02x:%02x:%02x:%02xn",
                  baseMac[0], baseMac[1], baseMac[2],
                  baseMac[3], baseMac[4], baseMac[5]);
  } else {
    Serial.println("Failed to read MAC address");
void setup(){
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.STA.begin();
  Serial.print("[DEFAULT] ESP32 Board MAC Address: ");
  readMacAddress();
void loop(){
通过串口读取到接收方ESP32开发板1的MAC地址为:
开发板
同样的方式读取到接收方ESP32开发板2的MAC地址为:
开发板
读取ESP8266开发板的代码
#include < ESP8266WiFi.h >
void setup(){
  Serial.println();
  Serial.print("ESP Board MAC Address:  ");
  Serial.println(WiFi.macAddress());
void loop(){
读取到接收方ESP8266开发板的MAC地址为:
开发板
ESP32发送方Sender程序
把ESP32开发板1,ESP开发板2,ESP8266开发板的MAC地址分别填入到下列代码的broadcastAddress1[ ],broadcastAddress2[ ],broadcastAddress3[ ]数组中
#include < esp_now.h >
#include < WiFi.h >
// REPLACE WITH YOUR ESP RECEIVER'S MAC ADDRESS
uint8_t broadcastAddress1[] = {0x54, 0x43, 0xb2, 0x7f, 0x00, 0x60};
uint8_t broadcastAddress2[] = {0x34, 0x5f, 0x45, 0xac, 0x16, 0xc0};
uint8_t broadcastAddress3[] = {0xdc, 0x4f, 0x22, 0x23, 0xca, 0x10};
typedef struct test_struct {
  int x;
  int y;
} test_struct;
esp_now_peer_info_t peerInfo;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  char macStr[18];
  Serial.print("Packet to: ");
  // Copies the sender mac address to a string
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.print(macStr);
  Serial.print(" send status:t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup() {
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_send_cb(OnDataSent);
  // register peer
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  memcpy(peerInfo.peer_addr, broadcastAddress1, 6);
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
  memcpy(peerInfo.peer_addr, broadcastAddress2, 6);
    return;
  memcpy(peerInfo.peer_addr, broadcastAddress3, 6);
    return;
void loop() {
  test_struct test;
  test_struct test2;
  test_struct test3;
  test.x = random(0,20);
  test.y = random(0,20);
  test2.x = random(0,20);
  test2.y = random(0,20);
  test3.x = random(0,20);
  test3.y = random(0,20);
  esp_err_t result1 = esp_now_send(
    broadcastAddress1,
    (uint8_t *) &test,
    sizeof(test_struct));
  if (result1 == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  delay(500);
  esp_err_t result2 = esp_now_send(
    broadcastAddress2,
    (uint8_t *) &test2,
  if (result2 == ESP_OK) {
  else {
  delay(500);
  esp_err_t result3 = esp_now_send(
    broadcastAddress3,
    (uint8_t *) &test3,
  if (result3 == ESP_OK) {
  else {
  delay(2000);
ESP32/ESP8266接收方Receiver程序
上传代码到ESP32开发板1和ESP3开发板2
#include < WiFi.h >
//Structure example to receive data
//Must match the sender structure
  int x;
  int y;
} test_struct;
//Create a struct_message called myData
test_struct myData;
//callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(len);
  Serial.print("x: ");
  Serial.println(myData.x);
  Serial.print("y: ");
  Serial.println(myData.y);
  Serial.println();
void setup() {
  //Initialize Serial Monitor
  //Set device as a Wi-Fi Station
  //Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(esp_now_recv_cb_t(OnDataRecv));
void loop() {
ESP8266开发板接收代码
#include < espnow.h >
  int x;
  int y;
} test_struct;
test_struct myData;
void OnDataRecv(uint8_t * mac, uint8_t *incomingData, uint8_t len) {
  Serial.println();
void setup() {
  //Init ESP-NOW
  if (esp_now_init() != 0) {
    return;
  esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
  esp_now_register_recv_cb(OnDataRecv);
void loop() {
ESP-NOW通信验证
同时给发送方ESP32开发板,接收方ESP32开发板1,接收方ESP32开发板2,接收方ESP8266开发板供电,并打开四个串口助手观察四个开发板的数据收发情况
若接收方都收到数据,发送方ESP32开发板会收到应答信息,串口打印各个MAC地址的接收方数据分发成功:
开发板
若有接收方没有收到数据,发送方ESP32开发板会收到应答信息,串口打印对应的MAC地址的接收方数据分发失败:
开发板
接收方ESP32开发板1串口打印接收到发送方发过来的随机数据
开发板
接收方ESP32开发板2串口打印接收到发送方发过来的随机数据
开发板
接收方ESP8266开发板串口打印接收到发送方发过来的随机数据
开发板
总结
通过以上例程验证了ESP32/ESP开发板之间单向一对多的ESP-NOW无线通信,接下来的篇章将继续验证多个的ESP32开发板之间实现多对一的ESP-NOW无线通信。
