在电子设计领域,总线开关是实现信号传输和切换的关键组件。今天,我们来深入了解SGMICRO推出的SGM65231,一款8位低电压高带宽总线开关,它在众多应用场景中展现出了出色的性能。
文件下载:SGM65231-Brief.pdf
SGM65231是一款8位、低电压且高带宽的总线开关。其数据I/O端口支持轨到轨切换,电源供应范围设计在2.3V至3.6V之间。该器件具有低导通电阻((R_{ON}))和低数据I/O电容的特点,这使得它能够实现最小的传播延迟,并最大程度地减少数据总线上的信号失真。
SGM65231适用于多种应用,如高带宽设备、宽带通信和数据密集型计算系统等。具体应用场景包括差分信号接口、PCI接口、低失真信号选通、内存交错和总线隔离等。
| MODEL | PACKAGE DESCRIPTION | SPECIFIED TEMPERATURE RANGE | ORDERING NUMBER | PACKAGE MARKING | PACKING OPTION |
| SGM65231 | TQFN - 4.5×3.5 - 20L - 40℃ to +125℃ | SGM65231XTQS20G/TR | SGM65231 XTQS20 XXXXX | Tape and Reel, 4000 | |
| TSSOP - 20 - 40℃ to +125℃ | SGM65231XTS20G/TR | SGM65231XTS20 XXXXX | Tape and Reel, 4000 |
其中,XXXXX代表日期代码、跟踪代码和供应商代码。
需要注意的是,超过绝对最大额定值的应力可能会对设备造成永久性损坏,长时间暴露在绝对最大额定值条件下可能会影响设备的可靠性。同时,在设计过程中要特别注意ESD保护,因为该集成电路如果不仔细考虑ESD保护措施,可能会受到损坏。
TQFN - 4.5×3.5 - 20L和TSSOP - 20两种封装的引脚配置如文档所示,这里不再赘述。
| TQFN - 4.5×3.5 - 20L/TSSOP - 20 PIN | NAME | I/O | FUNCTION |
| 1 | NC | - | No Internal Connection. |
| 2 | A1 | I/O | Bidirectional Analog Input/Output A1. |
| 3 | A2 | I/O | Bidirectional Analog Input/Output A2. |
| 4 | A3 | I/O | Bidirectional Analog Input/Output A3. |
| 5 | A4 | I/O | Bidirectional Analog Input/Output A4. |
| 6 | A5 | I/O | Bidirectional Analog Input/Output A5. |
| 7 | A6 | I/O | Bidirectional Analog Input/Output A6. |
| 8 | A7 | I/O | Bidirectional Analog Input/Output A7. |
| 9 | A8 | I/O | Bidirectional Analog Input/Output A8. |
| 10 | GND | - | Ground. |
| 11 | B8 | I/O | Bidirectional Analog Input/Output B8. |
| 12 | B7 | I/O | Bidirectional Analog Input/Output B7. |
| 13 | B6 | I/O | Bidirectional Analog Input/Output B6. |
| 14 | B5 | I/O | Bidirectional Analog Input/Output B5. |
| 15 | B4 | I/O | Bidirectional Analog Input/Output B4. |
| 16 | B3 | I/O | Bidirectional Analog Input/Output B3. |
| 17 | B2 | I/O | Bidirectional Analog Input/Output B2. |
| 18 | B1 | I/O | Bidirectional Analog Input/Output B1. |
| 19 | OE | I | Enable Control Input (Active Low). |
| 20 | V CC | - | Positive Power Supply. |
TQFN - 4.5×3.5 - 20L和TSSOP - 20两种封装都有详细的外形尺寸和推荐焊盘尺寸,具体尺寸可参考文档中的表格。需要注意的是,这些图纸可能会在不通知的情况下进行更改。
| Package Type | Reel Diameter | Reel Width (W1) | A0 (mm) | B0 (mm) | K0 (mm) | P0 (mm) | P1 (mm) | P2 (mm) | Pin1 Quadrant |
| TQFN - 4.5×3.5 - 20L | 13″ | 12.4 | 3.75 | 4.75 | 0.95 | 4.0 | 8.0 | 2.0 | Q1 |
| TSSOP - 20 | 13″ | 16.4 | 6.80 | 6.90 | 1.50 | 4.0 | 8.0 | 2.0 | Q1 |
对于13″的卷盘,纸箱的长度为386mm,宽度为280mm,高度为370mm,每个纸箱可装5个卷盘。
SGM65231作为一款性能出色的8位低电压高带宽总线开关,凭借其丰富的特性、广泛的应用领域和多种封装形式,为电子工程师在设计高带宽设备、宽带通信和数据密集型计算系统等方面提供了一个优秀的选择。在使用过程中,我们需要严格遵循其绝对最大额定值和推荐工作条件,注意ESD保护,以确保设备的正常运行和可靠性。大家在实际设计中,是否遇到过类似总线开关的应用难题呢?欢迎在评论区分享交流。
