在音频处理领域,一款高性能的数模转换器(DAC)对于提升音频质量至关重要。今天,我们将深入探讨Wolfson Microelectronics公司的WM8766,这是一款24位、192kHz的6通道DAC,广泛应用于DVD、环绕声处理等领域。
文件下载:WM8766GEDS/V.pdf
WM8766是一款多通道音频DAC,专为家庭高保真音响、汽车以及其他视听设备的DVD和环绕声处理应用而设计。它集成了三个立体声24位多位Σ - Δ DAC,并配备过采样数字插值滤波器,支持16 - 32位的数字音频输入字长和8kHz - 192kHz的采样率。每个DAC通道都具备独立的数字音量和静音控制功能。
| WM8766采用28引脚SSOP封装,各引脚功能明确。例如,MODE引脚用于控制格式选择,MCLK引脚提供主时钟,BCLK和LRCLK用于音频接口的位时钟和左右字时钟等。具体引脚配置如下表所示: | PIN | NAME | TYPE | DESCRIPTION |
| 1 | MODE | Digital input | Control format selection 0 = Software control 1 = Hardware control | |
| 2 | MCLK | Digital input | Master clock; 128, 192, 256, 384, 512 or 768fs (fs = word clock frequency) | |
| 3 | BCLK | Digital input/output | Audio interface bit clock | |
| 4 | LRCLK | Digital input/output | Audio left/right word clock | |
| 5 | DVDD | Supply | Digital positive supply | |
| 6 | DGND | Supply | Digital negative supply | |
| 7 | DIN1 | Digital input | DAC channel 1 data input | |
| 8 | DIN2 | Digital input | DAC channel 2 data input | |
| 9 | DIN3 | Digital input | DAC channel 3 data input | |
| 10 | DNC | Do not connect | Do not connect | |
| 11 | ML/I2S | Digital input | Software Mode: Serial interface Latch signal Hardware Mode: Input Audio Data Format | |
| 12 | MC/IWL | Digital input | Software Mode: Serial control interface clock Hardware Mode: Audio data input word length | |
| 13 | MD/DM | Digital input | Software Mode: Serial interface data Hardware Mode: De - emphasis selection | |
| 14 | MUTE | Digital input/output | DAC Zero Flag output or DAC mute input | |
| 15 | TESTREF | Analogue output | Test reference | |
| 16 | VREFN | Supply | DAC negative supply | |
| 17 | VREFP | Supply | DAC positive reference supply | |
| 18 | VMID | Analogue output | Midrail divider decoupling pin; 10uF external decoupling | |
| 19 | NC | No connect | No internal connection | |
| 20 | NC | No connect | No internal connection | |
| 21 | VOUT1L | Analogue output | DAC channel 1 left output | |
| 22 | VOUT1R | Analogue output | DAC channel 1 right output | |
| 23 | VOUT2L | Analogue output | DAC channel 2 left output | |
| 24 | VOUT2R | Analogue output | DAC channel 2 right output | |
| 25 | VOUT3L | Analogue output | DAC channel 3 left output | |
| 26 | VOUT3R | Analogue output | DAC channel 3 right output | |
| 27 | AGND | Supply | Analogue negative supply and substrate connection | |
| 28 | AVDD | Supply | Analogue positive supply |
| 在使用WM8766时,需要注意其绝对最大额定值,以避免设备损坏。例如,数字电源电压范围为 - 0.3V - +5V,模拟电源电压范围为 - 0.3V - +7V,主时钟频率最大为37MHz等。 | CONDITION | MIN | MAX |
| Digital supply voltage | -0.3V | +5V | |
| Analogue supply voltage | -0.3V | +7V | |
| Voltage range digital inputs | DGND - 0.3V | DVDD + 0.3V | |
| Voltage range analogue inputs | AGND - 0.3V | AVDD + 0.3V | |
| Master Clock Frequency | 37MHz | ||
| Operating temperature range, TA | -25°C | +85°C | |
| Storage temperature after soldering | -65°C | +150°C |
| 为了确保设备的正常运行,推荐的工作条件如下:数字电源范围为2.7V - 3.6V,模拟电源范围为2.7V - 5.5V,接地引脚电压为0V,DGND与AGND之间的电压差应在 - 0.3V - +0.3V之间。 | PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT |
| Digital supply range | DVDD | 2.7 | 3.6 | V | |||
| Analogue supply range | AVDD, VREFP | 2.7 | 5.5 | V | |||
| Ground | AGND, VREFN, DGND | 0 | V | ||||
| Difference DGND to AGND | -0.3 | 0 | +0.3 | V |
| WM8766在音频性能方面表现出色,例如在48kHz采样率下,SNR可达103dB(‘A’加权),动态范围可达103dB,总谐波失真(THD)在1kHz、0dBFs时小于 - 80dB等。 | PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT |
| Digital Logic Levels (CMOS Levels) | |||||||
| Input LOW level | VIL | 0.3 x DVDD | V | ||||
| Input HIGH level | VIH | 0.7 x DVDD | V | ||||
| Output LOW | VOL | IOL = 1mA | 0.1 x DVDD | V | |||
| Output HIGH | VOH | IOH = -1mA | 0.9 x DVDD | V | |||
| Analogue Reference Levels | |||||||
| Reference Voltage | VVMID | VREFP/2 | V | ||||
| Potential Divider Resistance | RVMID | (VREFP to VMID) and (VMID to VREFN) | 133 | kΩ | |||
| DAC Performance (Load = 10kΩ, 50pF) | |||||||
| 0dBFs Full Scale Output Voltage | 1.0 x VREFP/5 | Vrms | |||||
| SNR (Note 1,2,4) | A - weighted, @ fs = 48kHz | 95 | 103 | dB | |||
| SNR (Note 1,2,4) | A - weighted @ fs = 96kHz | 101 | dB | ||||
| SNR (Note 1,2,4) | A - weighted @ fs = 192kHz | 101 | dB | ||||
| SNR (Note 1,2,4) | A - weighted @ fs = 48kHz, AVDD = 3.3V | 101 | dB | ||||
| SNR (Note 1,2,4) | A - weighted @ fs = 96kHz, AVDD = 3.3V | 99 | dB | ||||
| Dynamic Range (Note 2,4) | DNR | A - weighted, - 60dB full scale input | 95 | 103 | dB | ||
| Total Harmonic Distortion (THD) | 1kHz, 0dBFs | -90 | -80 | dB | |||
| Mute Attenuation | 1kHz Input, 0dB gain | 100 | dB | ||||
| DAC Channel Separation | 100 | dB | |||||
| Power Supply Rejection Ratio | PSRR | 1kHz 100mVpp | 50 | dB | |||
| 20Hz to 20kHz 100mVp - p | 45 | dB | |||||
| Supply Current | |||||||
| Analogue Supply Current | AVDD, VREFP = 5V | 13.8 | mA | ||||
| Digital Supply Current | DVDD = 3.3V | 11.0 | mA |
| 主时钟MCLK的时序要求对于设备的正常运行至关重要。MCLK的脉冲宽度、周期时间和占空比等参数都有明确的规定。如果MCLK周期超过最大规定值,设备将进入节能模式,DAC会断电,内部数字音频滤波器会复位。当MCLK恢复时,DAC会自动上电,但需要写入音量更新寄存器位来恢复正确的音量设置。 | PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT |
| MCLK System clock pulse width high | tMCLKH | 11 | ns | ||||
| MCLK System clock pulse width low | tMCLKL | 11 | ns | ||||
| MCLK System clock cycle time | tMCLKY | 28 | 1000 | ns | |||
| MCLK Duty cycle | 40:60 | 60:40 | |||||
| Power - saving mode activated | After MCLK stopped | 2 | 10 | Us | |||
| Normal mode resumed | After MCLK re - started | 0.5 | 1 | MCLK cycle |
WM8766的数字音频接口支持主模式和从模式。在主模式下,LRCLK和BCLK是输出信号;在从模式下,LRCLK和BCLK是输入信号。同时,它支持多种音频接口格式,如左对齐、右对齐、I2S和DSP模式。
| 主模式:在主模式下,WM8766生成LRCLK和BCLK信号,DIN1/2/3在BCLK的上升沿采样。相关的时序参数如下: | PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT |
| LRCLK propagation delay from BCLK falling edge | tDL | 0 | 10 | ns | |||
| DIN1/2/3 setup time to BCLK rising edge | tDST | 10 | ns | ||||
| DIN1/2/3 hold time from BCLK rising edge | tDHT | 10 | ns |
| 从模式:在从模式下,LRCLK和BCLK作为输入信号,DIN1/2/3在BCLK的上升沿采样。相关的时序参数如下: | PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT |
| BCLK cycle time | tBCY | 50 | ns | ||||
| BCLK pulse width high | tBCH | 20 | ns | ||||
| BCLK pulse width low | tBCL | 20 | ns | ||||
| LRCLK set - up time to BCLK rising edge | tLRSU | 10 | ns | ||||
| LRCLK hold time from BCLK rising edge | tLRH | 10 | ns | ||||
| DIN1/2/3 set - up time to BCLK rising edge | tDS | 10 | ns | ||||
| DIN1/2/3 hold time from BCLK rising edge | tDH | 10 | ns |
| MPU接口采用3线SPI兼容控制接口,其输入时序有明确的要求,如MC/IWL上升沿到ML/I2S上升沿的时间、MC/IWL脉冲周期时间等。 | PARAMETER | SYMBOL | MIN | TYP | MAX | UNIT |
| MC/IWL rising edge to ML/I2S rising edge | tSCS | 60 | ns | |||
| MC/IWL pulse cycle time | tSCY | 80 | ns | |||
| MC/IWL pulse width low | tSCL | 30 | ns | |||
| MC/IWL pulse width high | tSCH | 30 | ns | |||
| MD/DM to MC/IWL set - up time | tDSU | 20 | ns | |||
| MC/IWL to MD/DM hold time | tDHO | 20 | ns | |||
| ML/I2S pulse width low | tCSL | 20 | ns | |||
| ML/I2S pulse width high | tCSH | 20 | ns | |||
| ML/I2S rising to MC/IWL rising | tCSS | 20 | ns |
当MODE引脚置高时,设备进入硬件控制模式。在该模式下,MUTE引脚可用于控制静音和自动静音功能,ML/I2S和MC/IWL用于选择输入数据格式和输入数据字长,MD/DM用于选择去加重滤波。
在软件模式下,WM8766通过3线串行接口进行控制。MD/DM用于传输程序数据,MC/IWL用于时钟信号,ML/I2S用于锁存程序数据。
WM8766的控制接口寄存器用于配置设备的各种功能,如衰减控制模式、DAC输出控制、数字音频接口控制等。通过对这些寄存器的设置,可以实现对设备的精确控制。
