在电子设计领域,选择一款合适的微控制器对于项目的成功至关重要。今天,我们将深入探讨Atmel公司的AT91FR40162微控制器,了解它的特性、架构以及应用中的注意事项。
文件下载:AT91FR40162-CI.pdf
AT91FR40162是Atmel AT91 16/32位微控制器家族的一员,基于ARM7TDMI处理器核心。它具有高性能的32位RISC架构和高密度的16位指令集,功耗极低。该微控制器集成了2Mbits的片上SRAM和2Mbytes的闪存,采用121球BGA封装,体积小巧,非常适合空间受限的应用。
AT91FR40162采用121球BGA封装,其引脚配置如图所示。每个引脚都有特定的功能,包括地址总线、数据总线、片选信号、中断信号等。
详细的引脚说明见下表,涵盖了各个模块的引脚功能、类型、有效电平以及相关注释。例如,EBI模块的地址总线A0 - A23用于输出地址信号,数据总线D0 - D15为I/O类型;AIC模块的FIQ为快速中断请求输入等。
| Module | Name | Function | Type | Active Level | Comments |
| EBI | A0 - A23 | Address Bus | Output | – | Valid after reset; do not reprogram A20 to I/O, as it is MSB of Flash address |
| D0 - D15 | Data Bus | I/O | – | ||
| NCS0 - NCS3 | External Chip Select | Output | Low | Used to select external devices | |
| CS4 - CS7 | External Chip Select | Output | High | A23 - A20 after reset | |
| NWR0 | Lower Byte 0 Write Signal | Output | Low | Used in Byte Write option | |
| NWR1 | Upper Byte 1 Write Signal | Output | Low | Used in Byte Write option | |
| NRD | Read Signal | Output | Low | Used in Byte Write option | |
| NWE | Write Enable | Output | Low | Used in Byte Select option | |
| NOE | Output Enable | Output | Low | Used in Byte Select option | |
| NUB | Upper Byte Select | Output | Low | Used in Byte Select option | |
| NLB | Lower Byte Select | Output | Low | Used in Byte Select option | |
| NWAIT | Wait Input | Input | Low | ||
| BMS | Boot Mode Select | Input | – | Sampled during reset; must be driven low during reset for Flash to be used as boot memory | |
| AIC | FIQ | Fast Interrupt Request | Input | – | PIO-controlled after reset |
| IRQ0 - IRQ2 | External Interrupt Request | Input | – | PIO-controlled after reset | |
| Timer | TCLK0 - TCLK2 | Timer External Clock | Input | – | PIO-controlled after reset |
| TIOA0 - TIOA2 | Multi-purpose Timer I/O Pin A | I/O | – | PIO-controlled after reset | |
| TIOB0 - TIOB2 | Multi-purpose Timer I/O Pin B | I/O | – | PIO-controlled after reset | |
| USART | SCK0 - SCK1 | External Serial Clock | I/O | – | PIO-controlled after reset |
| TXD0 - TXD1 | Transmit Data Output | Output | – | PIO-controlled after reset | |
| RXD0 - RXD1 | Receive Data Input | Input | – | PIO-controlled after reset | |
| PIO | P0 - P31 | Parallel IO Line | I/O | – | |
| WD | NWDOVF | Watchdog Overflow | Output | Low | Open drain |
| Clock | MCKI | Master Clock Input | Input | – | Schmidt trigger |
| MCKO | Master Clock Output | Output | – | ||
| Reset | NRST | Hardware Reset Input | Input | Low | Schmidt trigger |
| NTRI | Tri-state Mode Select | Input | Low | Sampled during reset | |
| ICE | TMS | Test Mode Select | Input | – | Schmidt trigger, internal pull-up |
| TDI | Test Data Input | Input | – | Schmidt trigger, internal pull-up | |
| TDO | Test Data Output | Output | – | ||
| TCK | Test Clock | Input | – | Schmidt trigger, internal pull-up | |
| Flash Memory | NCSF | Flash Memory Select | Input | Low | Enables Flash Memory when pulled low |
| NBUSY | Flash Memory Busy Output | Output | Low | Flash RDY/BUSY signal; open-drain | |
| NRSTF | Flash Memory Reset Input | Input | Low | Resets Flash to standard operating mode | |
| Power | VDDIO | Power | Power | – | All V DDIO, V DDCORE and all GND pins MUST be connected to their respective supplies by the shortest route |
| VDDCORE | Power | Power | – | ||
| GND | Ground | Ground | – | ||
| VPP (1) | Faster Program/Erase Voltage | Power | – | See AT49BV/LV1604A/1614A (T) 2-Mbyte (1M x 16/2M x 8) 3-volt Only Flash Memory Datasheet |
AT91FR40162集成了Atmel的AT91R40008 ARM Thumb处理器和AT49BV1604A/1614A 2-Mbyte闪存芯片,采用121球BGA封装。其架构由先进系统总线(ASB)和先进外设总线(APB)组成。ASB连接ARM7TDMI处理器与片上32位SRAM、外部总线接口(EBI)和AMBA桥,以实现高性能操作;APB则用于访问片上外设,优化了功耗。
AT91FR40162有VDDCORE和VDDIO两种电源引脚,分别为芯片核心和I/O线及闪存供电,独立的I/O电源可灵活适应外部组件信号电平。
I/O引脚接受的电压电平最高为VDDIO电源限制,复位后,微控制器外设I/O初始化为输入,建议在应用中保持输入处于有效逻辑电平以降低功耗。
采用完全静态设计,主时钟(MCK)由外部源提供在MCKI引脚,MCKO引脚可输出主时钟信号,复位后需通过PIO控制器配置该引脚。
复位可恢复用户接口寄存器的默认状态,使ARM7TDMI从地址零开始执行指令。NRST引脚为低电平有效,异步断言,退出复位与MCK同步;看门狗可编程产生内部复位,但NRST引脚优先级更高。
所有基于闪存的AT91设备都预装了AT91 Flash Uploader软件,可通过串口对嵌入式闪存进行编程。该软件需要将封装的闪存作为引导内存,并在MCKI引脚提供有效时钟。
AT91FR40162的订购代码为AT91FR40162 - CI,采用BGA 121封装,适用于工业温度范围( -40°C至85°C)。
该微控制器采用121球BGA封装,具有特定的热阻数据、最大重量和封装特性,如球直径、球焊盘、焊锡掩膜开口等。
推荐的焊接曲线遵循J - STD - 20标准,包括平均升温速率、预热温度、高于183°C的保持时间、峰值温度范围、降温速率等参数。小封装可能需要承受更高的温度,具体的回流条件取决于封装厚度和体积。
AT91FR40162存在一些已知问题,如全芯片擦除命令可能无法完全擦除闪存、并发读取功能可能导致闪存访问错误、扇区擦除命令可能无法完全擦除扇区、闪存内存上传器(FMU)在某些批次的高速运行问题以及VPP电压过高可能导致部分扇区擦除失败等。针对这些问题,文档提供了相应的解决方法。
AT91FR40162以其高性能、低功耗和丰富的外设接口,为电子工程师提供了一个强大的解决方案。在设计过程中,充分了解其特性和注意事项,可以确保项目的顺利进行。你在使用AT91FR40162时遇到过哪些问题呢?欢迎在评论区分享你的经验。
