在电子设计领域,整流器是不可或缺的基础元件,其性能直接影响着整个电路的效率和稳定性。今天,我们就来深入探讨Nexperia推出的RB521CS30L 100 mA低VF MEGA肖特基势垒整流器,了解它的特点、应用以及相关技术参数。
文件下载:RB521CS30L315.pdf
RB521CS30L是一款平面最大效率通用型(MEGA)肖特基势垒整流器,它集成了保护环以实现应力保护,并采用SOD882无引脚超小型表面贴装器件(SMD)塑料封装。这种封装设计不仅节省了电路板空间,还能有效提高电路的集成度。
| Symbol | Parameter | Conditions | Min | Typ | Max | Unit |
| I F(AV) | average forward current | square wave; δ = 0.5; f = 20 kHz T amb ≤ 135 ° C T sp ≤ 145 ° C |
- | - | 100 | mA |
| I R | reverse current | V R = 10 V | - | 2 | 10 | μ A |
| V R | reverse voltage | - | - | 30 | V | |
| V F | forward voltage | I F = 10 mA Pulse test: (t_{p} ≤300 mu s) : (delta ≤0.02) |
- | 280 | 350 | mV |
| Symbol | Parameter | Conditions | Min | Max | Unit |
| V R | reverse voltage | - | 30 | V | |
- | 100 | mA |
| I FSM | non - repetitive peak forward current | half sine wave; t p ≤ 8.3 ms (T_{j}=25^{circ} C) prior to surge |
- | 3 | A |
| P tot | total power dissipation | T amb ≤ 25 ° C Device mounted on an FR4 PCB, single - sided copper, tin - plated and standard footprint Device mounted on an FR4 PCB, single - sided copper, tin - plated, mounting pad for cathode (1 ~cm^{2}) |
- | 315 565 |
mW |
| T j | junction temperature | - | 150 | ° C | |
| T amb | ambient temperature | - 65 | +150 | ° C | |
| T stg | storage temperature | - 65 | +150 | ° C |
| R th(j - a) | thermal resistance from junction to ambient | in free air Device mounted on an FR4 PCB, single - sided copper, tin - plated and standard footprint Device mounted on an FR4 PCB, single - sided copper, tin - plated, mounting pad for cathode (1 ~cm^{2}) |
- | - | 395 220 |
K/W |
| R th(j - sp) | thermal resistance from junction to solder point | Soldering point of cathode tab | - | - | 70 | K/W |
文档中给出了典型波形的电流额定值计算方法,对于直流情况,(I{RMS}=I{F(AV)});对于非直流情况,(I{RMS}=I{M} ×sqrt{delta}),其中(I{F(AV)}=I{M} ×delta),(I_{M})为峰值电流。
该产品已通过汽车电子委员会(AEC)标准Q101的认证,适用于汽车应用,这意味着它在可靠性和稳定性方面有较高的保障。
采用SOD882无引脚超小型塑料封装,尺寸为1.0 × 0.6 × 0.5 mm,引脚定义明确,引脚1为阴极,引脚2为阳极。
产品采用2 mm间距、8 mm带盘包装,每盘数量为10000个。
文档明确指出,回流焊是唯一推荐的焊接方法,并给出了回流焊的焊盘尺寸等相关信息。
在使用该整流器时,需要注意其极限值,应力超过极限值可能会导致器件永久性损坏。同时,Nexperia产品不适合用于生命支持、生命关键或安全关键系统,使用时需根据实际应用情况进行评估和测试。
Nexperia RB521CS30L 100 mA低VF MEGA肖特基势垒整流器凭借其低功耗、高可靠性等特点,在低电压整流、DC - DC转换等领域具有广泛的应用前景。电子工程师在设计电路时,可以根据具体需求合理选择该器件,以提高电路的性能和稳定性。大家在实际应用中是否遇到过类似整流器的使用问题呢?欢迎在评论区分享交流。
