在当今数字化时代,HDMI接口已成为电子设备间传输高清音视频信号的标准配置。ON Semiconductor推出的CM2021 - 02TR HDMI接收器端口保护和接口设备,为下一代HDMI主机接口保护提供了卓越的解决方案。
文件下载:CM2021-02TR.pdf
CM2021 - 02TR专为下一代HDMI主机接口保护而设计,它将ESD保护、电平转换和反向驱动保护功能集成在一个38引脚的TSSOP封装中。这种集成化设计不仅节省了电路板空间,还简化了HDMI端口的设计流程。该产品与HDMI 1.3标准兼容,适用于PC、消费电子、显示器和数字电视等多种应用场景。
CM2021 - 02TR的引脚功能丰富多样,不同引脚承担着不同的任务。例如,TMDS信号引脚提供0.9 pF的ESD保护,CE_REMOTE、DDC和HOTPLUG相关引脚则具有特定的电平转换和ESD保护功能。在设计过程中,需要根据引脚的功能和特性进行合理的连接和布局。
| Pins | Name | ESD Level | Description |
| 4,35 | TMDS D2+ | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 6,33 | TMDS D2- | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 7,32 | TMDS D1+ | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 9,30 | TMDS D1- | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 10,29 | TMDS DO+ | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 12,27 | TMDS DO- | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 13.26 | TMDS_CK+ | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 15,24 | TMDS CK- | 8 kV (Note 2) | TMDS 0.9 pF ESD Protection (Note 1) |
| 16 | CE REMOTE IN | 2 kV (Note 3) | LV_SUPPLY Referenced Logic Level into ASIC |
| 23 | CE_REMOTE_OUT | 8 kV(Note 2) | 5V_SUPPLY Referenced Logic Level Out plus 3.5 pF ESD to Connector |
| 17 | DDC CLK_IN | 2 kV (Note 3) | LV_SUPPLY Referenced Logic Level into ASIC |
| 22 | DDC_CLK_OUT | 8 kV (Note 2) | 5V_SUPPLY Referenced Logic Level Out plus 3.5 pF ESD to Connector |
| 18 | DDC_DAT_IN | 2 kV (Note 3) | LV_SUPPLY Referenced Logic Level into ASIC |
| 21 | DDC_DAT_OUT | 8 kV (Note 2) | 5V_SUPPLY Referenced Logic Level Out plus 3.5 pF ESD to Connector |
| 19 | HOTPLUG DET IN | 2 kV (Note 3) | LV_SUPPLY Referenced Logic Level into ASIC |
| 20 | HOTPLUG_DET_OUT | 8 kV (Note 2) | 5V_SUPPLY Referenced Logic Level Out plus 3.5 pF ESD to Connector |
| 2 | LV_SUPPLY | 2 kV (Note 3) | Bias for CE/DDC / HOTPLUG Level Shifters |
| 1 | 5V_SUPPLY | 2 kV (Note 3) | Current Source for 5V_OUT |
| 37 | ESD_BYP | 2 kV (Note 3) | This Pin may be Connected to a 0.1 F Ceramic Capacitor, but it is not necessary. |
| 5,34,8, 31, 11, 28, 14,25 | TMDS_GND | N/A | TMDS ESD and Parasitic GND Return (Note 4) |
| 3,36 | GND | N/A | Supply GND Reference |
| 38 | NC | N/A | No Connect |
典型应用电路展示了CM2021 - 02TR与HDMI连接器和ASIC的连接方式。在设计时,需要注意差分TMDS对的设计应遵循100 Ω HDMI微带线的标准,单端TMDS走线应进行调谐以匹配芯片和连接器的寄生参数。
CM2021 - 02TR是一款功能强大的HDMI接收器端口保护和接口设备,它集成了多种保护功能,能够为HDMI端口提供可靠的防护。在设计过程中,工程师需要充分了解其特性、引脚功能、规格参数和应用注意事项,以确保设备的性能和稳定性。你在使用CM2021 - 02TR的过程中遇到过哪些问题呢?欢迎在评论区分享你的经验和见解。
