在电子设计领域,电源管理是至关重要的一环。今天要给大家介绍的是STMicroelectronics推出的L4971,一款1.5A降压开关稳压器,它具备诸多出色的特性,能满足多种应用场景的需求。
文件下载:EVAL4971.pdf
L4971能够实现高达1.5A的降压转换,其工作输入电压范围为8V至55V,输出电压可在3.3V至50V之间进行调节,这使得它能覆盖当今大多数应用场景。无论是低电压的小型设备,还是高电压的工业应用,L4971都能轻松应对。
它拥有精确的3.3V(±1%)内部参考电压,并且输出电压可调。同时,开关频率可调节至300KHz,还具备电压前馈功能,能更好地适应不同的负载变化,提高电源的稳定性。
这款稳压器具备零负载电流操作、内部电流限制(脉冲逐个和打嗝模式)、反馈断开保护、热关断以及软启动功能等。这些保护机制能有效防止设备在异常情况下受损,提高系统的可靠性。
L4971采用BCD混合技术,内部使用功率D - MOS晶体管(典型Rdson为0.25Ω),从而获得了非常高的效率和高开关速度。
| 它提供两种封装形式,分别是DIP8(适用于标准组装)和SO16W(适用于SMD组装),方便不同的设计需求。具体的订单代码如下: | Part Number | Package |
| L4971 | DIP8 | |
| L4971D | SO16W | |
| L4971D013TR | SO16 in Tape & Reel |
| L4971的引脚功能清晰明确,不同引脚承担着不同的职责。例如,GND为接地引脚;SS_INH引脚可通过逻辑信号(低电平有效)禁用设备,同时连接电容可确定软启动时间;OSC引脚通过外部电阻和电容来固定开关频率等。具体引脚描述如下表: | DIP | SO (*) | Name | Function |
| 1 | 2 | GND | Ground | |
| 2 | 3 | SS_INH | A logic signal (active low) disables the device (sleep mode operation). A capacitor connected between this pin and ground determines the soft start time. When this pin is grounded disabled the device (driven by open collector/drain). | |
| 3 | 4 | OSC | An external resistor connected between the unregulated input voltage and this pin and a capacitor connected from this pin to ground fix the switching frequency. (Line feed forward is automatically obtained) | |
| 4 | 5, 6 | OUT | Stepdown regulator output | |
| 5 | 11 | V CC | Unregulated DC input voltage | |
| 6 | 12 | BOOT | A capacitor connected between this pin and OUT allows to drive the internal DMOS Transistor | |
| 7 | 13 | COMP | E/A output to be used for frequency compensation | |
| 8 | 14 | FB | Stepdown feedback input. Connecting directly to this pin results in an output voltage of 3.3V. An external resistive divider is required for higher output voltages. |
注:(*) Pins 1, 7, 8, 9, 10, 15 and 16 are not internally, electrically connected to the die.
| 了解产品的绝对最大额定值对于正确使用和设计电路至关重要。L4971的输入电压最大为58V,输出直流电压最小为 - 1V等,具体参数如下表: | Symbol | Parameter | Value | Unit | ||
| Minidip | S016 | |||||
| V 5 | V 11 | Input voltage | 58 | V | ||
| V 4 | V 5 ,V 6 | Output DC voltage | -1 | V | ||
| Output peak voltage at t = 0.1 µ s f=200KHz | -5 | V | ||||
| I 4 | I 5 ,I 6 | Maximum output current | int. limit. | |||
| V 6 -V 5 | V 12 -V 11 | 14 | V | |||
| V 6 | V 12 | Bootstrap voltage | 70 | V | ||
| V 7 | V 13 | Analogs input voltage (V CC = 24V | 12 | V | ||
| V 2 | V 3 | Analogs input voltage (V CC = 24V) | 13 | V | ||
| V 8 | V 14 | (V CC = 20V) | 6 -0.3 | V V | ||
| P tot | Power dissipation a Tamb ≤ 60°C | DIP8 | 1 | W | ||
| SO16 | 0.8 | W | ||||
| T j ,T stg | Junction and storage temperature | -40 to 150 | ° C |
在电气特性方面,L4971表现出色。例如,其工作输入电压范围为8V至55V,输出电压在不同负载和输入电压条件下都能保持稳定。在典型测试条件下((T{j}=25^{circ} C) , (Cosc=2.7 nF) , (R O S C=20 k Omega) , (V{C C}=24 ~V) ),输出电压在不同负载下的变化范围在3.22V至3.5V之间。同时,它还具有较高的效率,在输出电压为3.3V、输出电流为1.5A时,效率可达85%。
| 通过评估板测试,L4971在不同输出电压下的表现如下: | Output Voltage | Output Ripple | Efficiency V CC =35V I O = 1.5A | Line Regulation I o = 1.5A V CC = 8 to 55V | Load Regulation V CC =35V I O = 0.5 to 1.5A |
| 3.3V | 10mV | 84 (%) | 3mV | 6mV | |
| 5.1V | 10mV | 86 (%) | 3mV | 6mV | |
| 12V | 12mV | 93 (%) | 3mV (V CC =15 to 55V) | 4mV |
文档中还给出了测试和评估板电路,以及PCB和组件布局图,为工程师进行实际设计提供了很好的参考。同时,还给出了不同输出电压下的电阻参数,方便工程师根据实际需求进行调整。
L4971作为一款高性能的降压开关稳压器,凭借其宽电压范围、高功率输出、全面的保护功能以及良好的电气特性,在电源管理领域具有很大的应用潜力。无论是在工业控制、通信设备还是消费电子等领域,都能为设计提供可靠的电源解决方案。各位工程师在进行电源设计时,不妨考虑一下L4971,相信它会给你带来意想不到的效果。你在使用类似稳压器的过程中遇到过哪些问题呢?欢迎在评论区分享。
