常用高频发射三级管资料,RF transistor datasheet
关键字:常用高频发射三级管资料
下面列出的一些常用高频发射三级管资料,或许可以给大家参考
型号 s 功率 增益 电压 频率 工作状态 封装 123脚
2N3375           10W          5dB         28V        400MHz     FM/AM/SSB   TO-60
2N3553           2,5W         10dB        28V       175MHz      FM/AM    TO-39 C B E
2N3632           20W           7dB         28V     175MHz     FM     TO-60
2N3866           5W            10dB        28V            400MHz            WINTransceiver  TO-39 C B E
2N3924            4W            6dB         13,6V            175MHz            WINTransceiver  TO-39
2N4427            2W            10dB        12V            175MHz            WINTransceiver   TO-39
2N5108            1W            5dB          24V            1200MHz            WINTransceiver    TO-39
2N5109            3,5W         11dB        15V            200MHz            WINTransceiver   TO-39
2N5421            3W            9dB          13,5V            175MHz            WINTransceiver    TO-39
2N5913            2W            7dB          12,5V            175MHz            WINTransceiver    TO-39
2N5943            1W            8dB          15V            400MHz            FM            TO-39
2SC730            0,8W            10dB            13,5V            175MHz            FM            TO-39 C B E
2SC1096            10W   60MHz            FM            TO-220
2SC1173     10W   100MHz   FM/AM/SSB   TO-220
2SC1306     16W   30MHz     FM/AM/SSB   TO-220 B C E
2SC1307     16W     12dB     12V     30MHz     FM/AM/SSB     TO-220 B C E
2SC1590     5W       10dB     12,5V     136-174MHz     FM     TO-220 B E C
2SC1591     14W     7,5dB    12,5V     136-174MHz     FM     TO-220 B E C
2SC1678     5W    30MHz     WINTransceiver     TO-220 B C E
2SC1728     8W    80MHz     WINTransceiver     TO-202 E B C
2SC1729     14W    10dB       13,5V     175MHz FM T-31E
2SC1909     10W    14,5dB    13,5V     50MHz FM/AM/SSB TO-220 B C E
2SC1944     13W    11,1dB    12V        30MHz WINTransceiver TO-220 B C E
2SC1945     16W    14,5dB    12V        30MHz FM/AM/SSB TO-220 B E C
2SC1946     25W    6,7dB      13,5V     175MHz FM T-31E
2SC1946A   30W   10dB        13,5V     175MHz FM T-31E
2SC1947     3W     10dB        13,5V     175MHz FM TO-39 C B E
2SC1957     1,8W  17dB        12V        30MHz  WINTransceiver TO-126 E C B
2SC1966     3W     7,8dB       13,5V     470MHz FM T-31E
2SC1967     7W     6,7dB       13,5V     470MHz FM T-31E
2SC1968     14W   3,7dB       13,5V     470MHz FM T-31E
2SC1968A   14W   5,4dB       13,5V     470MHz FM T-31E
2SC1969     18W   12dB        12V        30MHz FM/AM/SSB TO-220 B C E
2SC1970     1,5W  10dB        13,5V     175MHz WINTransceiver TO-220 B E C
2SC1971     7W     10dB        13,5V     175MHz WINTransceiver TO-220 B E C
2SC1972     14W   10dB        13,5V     175MHz WINTransceiver TO-220 B E C
2SC1973     1W   50MHz WINTransceiver TO-92L B C E
2SC1974     13W   10dB       13,5V     30MHz WINTransceiver TO-220 B C E
2SC1975     4W     10dB       13,5V     30MHz WINTransceiver TO-220 B C E
2SC2028     1,8W   30MHz   WINTransceiver TO-126 E C B
2SC2029     6W       30MHz   WINTransceiver TO-220 B C E
2SC2036A   1,4W     WINTransceiver TO-202 B C E
2SC2050     10W   12dB        13,5V     30MHz FM/AM/SSB TO-220 B C E
2SC2053     0,2W  15,7dB     12V        175MHz FM/AM TO-92L B C E
2SC2055     0,25W 15,3dB    12V        175MHz FM/AM TO-92L B C E
2SC2056     1,5W     9dB       12V        175MHz FM TO-39 C B E
2SC2075     4W       13,5V       27MHz WINTransceiver TO-220 B C E
2SC2078     4W       13dB       12V      100MHz FM/AM TO-220 B C E
2SC2086     0,45W  13dB       12V      175MHz FM/AM TO-92L B C E
2SC2092     4W       13dB       12V      100MHz FM/AM/SSB TO-220 B C E
2SC2094     15W     8,8dB      13,5V   175MHz FM/AM/SSB T-31E
2SC2166     6W      13,8dB     12V      30MHz FM/AM/SSB TO-220 B C E
2SC2207     16W     WINTransceiver TO-220 B C E
2SC2237     6W      13,8dB    13,5V    175MHz FM T-31E
2SC2312     18,5W   27MHz FM/AM/SSB TO-220 B C E
2SC2314     1,8W    17dB    12V     180MHz FM/AM TO-126 E C B
2SC2509     13W     14dB    30MHz WINTransceiver TO-220 B C E
2SC2527     60W     WINTransceiver TO-220
2SC2538     0,6W    10dB    12V     175MHz FM/AM TO-92L B C E
2SC2539     14W     14,5dB 13,5V   175MHz FM T-31E
2SC2660     30W   30MHz WINTransceiver TO-220
2SC2695     23W     1,9dB     13,5V     520MHz FM T-31E
2SC3001     6W       13dB      7,2V       175MHz FM T-31E
2SC3017     1W       11dB      13,5V     175MHz FM TO-39 C B E
2SC3018     3W       13dB      7,2V       175MHz FM T-31E
2SC3020     3W       10dB      12,5V     520MHz FM T-31E
2SC3021     7W       7,7dB     12,5V     520MHz FM T-31E
2SC3022     18W     4,8dB     12,5V     520MHz FM T-31E
2SC3103     2,8W    6,7dB     7,2V       520MHz FM T-31E
2SC3104     6W       4,8dB     7,2V       520MHz FM T-31E
2SC3133     13W     14dB     12V         1,5-30MHz FM/AM/SSB TO-220 B E C
2SC3297     15W   100MHz WINTransceiver TO-220
2SC3299     20W     WINTransceiver TO-220
2SC3668     1W   100MHz WINTransceiver
2SC3807     15W   260MHz WINTransceiver TO-126
2SC4137     4W   400MHz WINTransceiver TO-126
2SC4693       FM/AM TO-92L B C E
KTC1006     1W   100MHz FM/AM TO-92L E C B
KTC1969     16W        12dB        12V        100MHz FM/AM TO-220 B C E
KTC2078      4W        11dB        12V        100MHz FM/AM TO-220 B C E
MRF161        5W        13,5dB        12,5V        225-500MHz FM/AM TO-220 B E C
MRF162       15W        13,5dB        12,5V        225-500MHz FM/AM TO-220 B E C
MRF163        25W        12dB        12,5V        225-500MHz FM/AM TO-220 B E C
MRF237        4W        12dB        18V        175MHz WINTransceiver TO-39
MRF260        5W        10dB        12,5V        136-174MHz FM TO-220 B E C
MRF261        10W        5,2dB        12,5V        136-174MHz FM TO-220 B E C
MRF262        14W        7,5dB        12,5V        136-174MHz FM TO-220 B E C
MRF264        30W        5,2dB        12,5V        136-174MHz WINTransceiver TO-220 B E C
MRF340        8W        13dB        28V        70MHz WINTransceiver TO-220 B E C
MRF342        24W        11dB        28V        70MHz WINTransceiver TO-220 B E C
MRF344        60W        6dB        28V        70MHz WINTransceiver TO-220
MRF454        80W        12dB        12,5V        1,5-30MHz FM/AM/SSB
MRF455        60W        13dB        12,5V        1,5-30MHz FM/AM/SSB
MRF475        12W        10dB        13,5V        1,5-30MHz FM/AM/SSB TO-220 B C E
MRF476        3W        15dB        13,5V        1,5-30MHz FM/AM/SSB TO-220 B C E
MRF477        40W        15dB        13,5V        1,5-30MHz FM/AM/SSB TO-220 B E C
MRF479        15W        10dB        13,5V        1,5-30MHz FM/AM/SSB TO-220
MRF485        15W        10dB        28V        1,5-30MHz WINTransceiver TO-220
MRF486        40W        15dB        28V        1,5-30MHz WINTransceiver TO-220
MRF496        40W        15dB        13,5V        1,5-30MHz WINTransceiver TO-220
MRF497        60W        10dB        13,5V        27-50MHz WINTransceiver TO-220 B E C
MRF517        0,75W        10dB        20V        1000MHz WINTransceiver TO-39
MRF607        1,75W        11,5dB        16V        175MHz WINTransceiver TO-39
MRF660        7W        5,4dB        12,5V        400-512MHz WINTransceiver TO-220
MS1226        30W        18dB        28V        30MHz FM/AM/SSB
MS1227        20W        15dB        12,5V        30MHz FM/AM/SSB
  • 相关推荐
  • 热点推荐
