RK系列核心板+JL6110,国产交换机芯片适配指导
前言:
在工业物联网和边缘计算场景中,多网口需求日益普遍。传统方案依赖进口交换芯片,不仅成本高昂,供应链风险也不容忽视。景略半导体(JLSemi)推出的JL6110国产交换机芯片,以其低功耗、高集成度的特性,成为国产化替代的理想选择。
本文基于眺望电子RK3568核心板平台,详细记录JL6110交换机芯片的MAC-to-MAC适配全过程,涵盖设备树配置、驱动移植、调试技巧及性能验证,为同类项目提供实战参考。
一、MAC-to-MAC连接架构
 1.1  硬件连接方式
SoC内部MAC控制器与交换机芯片MAC采用RGMII直连方案:
MAC0 --RGMII-- MAC1TXD[3:0]  →  RXD[3:0]TX_EN     →  RX_DVTX_CLK    →  RX_CLKRXD[3:0]  ←  TXD[3:0]RX_DV     ←  TX_ENRX_CLK    ←  TX_CLK
 1.2  关键Strap Pin配置
JL6110的SMI_SEL引脚为典型Strap Pin(启动配置脚),用于选择管理接口类型:
SMI_SEL_1SMI_SEL_0模式
00I2C(LSB地址模式)
01I2C(MSB地址模式)
10MDIO / SMI(推荐)
11Lite I2C
推荐配置为10(MDC/MDIO模式),与RK3568 GMAC控制器兼容。
芯片二、设备树配置详解
RK3568支持双GMAC控制器,均可配置为MAC-to-MAC模式:
&gmac0 {    status = "okay";    phy-mode = "rgmii";    clock_in_out = "output";    assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>;    assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>;    assigned-clock-rates = <0>, <125000000>;    snps,reset-gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_LOW>;    snps,reset-active-low;    snps,reset-delays-us = <0 10000 2000000>;    pinctrl-names = "default";    pinctrl-0 = <&gmac0_miim             &gmac0_tx_bus2             &gmac0_rx_bus2             &gmac0_rgmii_clk             &gmac0_rgmii_bus>;    tx_delay = <0x4a>;    // rx_delay = <0>;    fixed-link {        speed = <1000>;        full-duplex;    };};&gmac1 {    status = "okay";    phy-mode = "rgmii";    clock_in_out = "output";    assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;    assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>;    assigned-clock-rates = <0>, <125000000>;    snps,reset-gpio = <&gpio1 RK_PB0 GPIO_ACTIVE_LOW>;    snps,reset-active-low;    snps,reset-delays-us = <0 10000 2000000>;    pinctrl-names = "default";    pinctrl-0 = <&gmac1m1_miim             &gmac1m1_tx_bus2             &gmac1m1_rx_bus2             &gmac1m1_rgmii_clk             &gmac1m1_rgmii_bus>;    tx_delay = <0x4a>;      // rx_delay = <0x20>;      fixed-link {        speed = <1000>;        full-duplex;    };};&mdio0 {rgmii_phy0: phy@0 {compatible = "ethernet-phy-ieee802.3-c22";reg = <0x0>;};};&mdio1 {rgmii_phy1: phy@0 {compatible = "ethernet-phy-ieee802.3-c22";reg = <0x0>;};};
关键配置说明:
- fixed-link节点表示MAC-to-MAC直连,无需外部PHY
- phy-handle属性需注释掉,避免驱动尝试外部PHY通信
- tx_delay值需根据实际PCB走线调整(通常0x4a-0x50)
三、JL6110驱动移植
 3.1  内核配置
移植JL6110 SDK后,需在内核配置中启用SMI interface支持:
Device Drivers → Network device support → Ethernet driver support →JLSemi Switch Support → SMI interface
芯片
 3.2  驱动适配
JL6110驱动使用port_mdio_read/port_mdio_write函数与硬件通信,需适配为RK3568内核的mdiobus_read/mdiobus_write接口:
extern struct mii_bus *jl_mii_bus, *jl_mii_bus1;void port_mdio_write(jl_io_desc_t *io_desc,            jl_uint8 phy, jl_uint8 reg, jl_uint16 val){    if ((io_desc->smi.mdio.bus_id & 0xffffff)==0) {        mdiobus_write(jl_mii_bus, (int)phy, (u32)reg, val);    } else if ((io_desc->smi.mdio.bus_id & 0xffffff)==1){        mdiobus_write(jl_mii_bus1, (int)phy, (u32)reg, val);    }}jl_uint16 port_mdio_read(jl_io_desc_t *io_desc,            jl_uint8 phy, jl_uint8 reg){    int data = 0;    if ((io_desc->smi.mdio.bus_id & 0xffffff)==0) {        data = mdiobus_read(jl_mii_bus, (int)phy, (u32)reg);    } else if ((io_desc->smi.mdio.bus_id & 0xffffff)==1){        data = mdiobus_read(jl_mii_bus1, (int)phy, (u32)reg);    }    return (jl_uint16)(data & 0xffff);}
四、调试与验证
 4.1  驱动加载检查
正常加载后,内核日志应显示:
芯片
网口驱动正常如下打印信息:
芯片
 4.2  PHY ID验证
通过debug接口读取芯片ID确认通信正常:
echo -r -a 0x244008 -s 1 > /proc/jlmdio/debug  # 应返回0x937Cecho -r -a 0x24400C -s 1 > /proc/jlmdio/debug  # 应返回0x4031
 4.3  功能实测
4.3.1 动态IP获取
将网线插入6个RJ45的任意一个,可执行以下命令手动获取 IP 地址:
ifconfig eth0 upudhcpc -i eth0ping www.baidu.com -I eth0 -c 5
芯片
4.3.2  iperf带宽测试
iperf -c 192.168.0.7 -t 5 -i 1
芯片
带宽稳定在900Mbps以上。
4.3.3 光口测试&交换机功能测试
将光模块和光纤插上SFP1(系统节点为eth1),测试方法与电口测试方法一致。交换机其余网口之间可互通。
总结
通过本文介绍的MAC-to-MAC适配方案,眺望电子RK3568核心板可稳定驱动JL6110国产交换机芯片,实现:
双GMAC控制器同时工作
12路千兆电口+1路光口扩展
驱动层完整适配,内核级稳定运行
iperf实测带宽900Mbps+
国产化替代不仅是供应链安全的选择,更是技术自主可控的必经之路。眺望电子将持续深耕国产化生态适配,为工业嵌入式领域提供可靠、可控的硬件解决方案。更多资料获取可以关注我们公众号或者同事联系获取。
